Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 07-20-2012, 04:52 PM   #1
clay soil in crawl space
We have clay soil in the crawl space under the house. One section is damp and probably caused from the sprinklers outside the house. We are going to move the sprinklers but how can we improve the soil in the crawl space to soak up the moisture and prevent future water from pooling?
shannonsull is offline   Reply With Quote
Old 07-21-2012, 06:18 AM   #2
WickedWarrior88's Avatar
Add sand to the clay. Sand will soak up water. But make sure you mix it into the clay and deep enough to handle heavy rain.
WickedWarrior88 is offline   Reply With Quote
Old 07-21-2012, 07:18 AM   #3
You need to regrade the land so water flows away from the house.
Mixing clay surface soil with sand is more suited to preparing the soil for planting as opposed to controlling flooding. Once soaked into the soil the water still has to go somewhere.
Excavating the first 12 to 18 inches in from the perimeter all the way down to the footing bottoms (or down to more porous subsoil if you get there first) and backfilling with pure sand or gravel is superior to taking up a layer of clay soil over the entire area of the crawl space and mixing with sand.
Do not excavate all around a column footing such as used for deck support posts or houses on stilts. I am guessing that it is safe to excavate up to a column footing no more than on two opposite sides not getting within 18 inches.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 07-26-2012, 05:06 PM   #4
Wire Chewer
Red Squirrel's Avatar
May have to redo the weeping tiles and foundation seal.... I just went through that, not cheap! You could also try regrading and that alone may help. is it only when you use the sprinkler or when it rains too? But redoing weeping tiles is best bet. At some time you'll get all that clay out of there as there is probably clay right up against the house, it does not absorb water as well.
Air Barrier in crawl space biglurr54 Insulation 6 01-15-2012 09:50 AM
Bad smell in crawl space. John_W General Discussion 28 10-20-2011 11:24 AM
mushroom in crawl space!??!! cbzdel General Discussion 2 09-24-2010 06:01 AM
Cement crawl space ventilation sheslostcontrol HVAC 9 05-22-2010 09:32 AM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 01:09 PM
