1] If I put a cisten in below ground level how do I prevent the cistern from 'popping up' during periods of high water level?
Ayuh,... I'll admit,... I've never Tried what you're proposing,....
But,...
I'd Think that you'd keep the cistern absolutely Full,.. Whenever there's
Any flow from the creek,..
And when it's Full, it shouldn't try to lift up.....
I'd also Think that if you Bottom fill the tank, You'd have what's known around here as a "Shore Well".... Not a cistern at all....
And I can tell you that when the water goes down, or in your case the creek stops flowing,....
Shore Wells usually go Dry.....
But, if the water table is as High as you say,... It just might work...
Btw,....
No Matter What you do,... Tree Roots will follow the Water.....
