Choosing Lumber For Raised Vegetable Beds - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-05-2013, 04:21 PM   #1
Rewards Points: 422
Choosing lumber for raised vegetable beds
Is the new treated lumber safe to use for this? If not, is there anything cheaper than cedar I can use? Thanks.
Jim McC is offline   Reply With Quote
Old 10-05-2013, 04:50 PM   #2
Devil Dog
handyman_20772's Avatar
Rewards Points: 77
No it's not safe to use, as the new lumber will still leach into the soil. You may want to think about using composite decking (which is still a little costly), or just use regular 2x material. I built mine with 2x10's and it held up pretty well for 3 years.
handyman_20772 is offline   Reply With Quote
Old 10-05-2013, 05:31 PM   #3
Rewards Points: 422
Thanks. You used regular pine? On Menards' website, it lists the treated lumber as "environmentally friendly". Does anyone know what that means?
Old 10-05-2013, 06:01 PM   #4
Rewards Points: 13,260
Look right on the tags on the end of pressure treated wood.
2X's are not below ground rated.
The old pressure treated wood was treated with arsenic, the newer wood it treated with copper.
I use pressure treated 6 X 6's and 4 X 4's all the time for raised gardens.
Composite not only is expensive but has about 0 side load strength. Unless you plan on supports every few ft. it's going to just bow out or look like a snake.
Old 10-05-2013, 09:49 PM   #5
Rewards Points: 422
Old 10-06-2013, 11:08 AM   #6
K&B Designer
Live_Oak's Avatar
There's nothing wrong with today's copper treated wood being used around edibles.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Old 10-06-2013, 12:59 PM   #7
Civil Engineer
Rewards Points: 4,566
I built several raised beds using cedar. Don't know about your area, but cedar where I live is about the same price as PT lumber. Some of my boxes have lasted ten years and still look OK. This is in direct contact with ground. Then again, I built some boxes using ordinary pine 2x10, they have lasted pretty well also.
Daniel Holzman is online now   Reply With Quote
Doug fir vs pressure treated or redwood for a painted fence? Bigb142 Painting 6 04-26-2012 10:43 PM
Milled lumber suitable for home construction? AlexHouse Building & Construction 25 02-29-2012 01:37 AM
Cheapest place to buy lumber - home improvement store or lumber supplier? J S Machine General DIY Discussions 23 01-13-2011 06:17 PM
