Changing Weed Eater Spool - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-25-2012, 10:32 PM   #1
Changing weed eater spool
I bought a cheap weed eater from Walmart called a Featherlite FL25. It is a gas trimmer with a .065 spool on it. Got it basically for 2 reasons. #1 it was super lite for my wife and #2 if she tears it up (which she will) I am not out a bunch of money. Now my problem is that it uses .065 string. I want to be able to use .095 string. Is there a universal bump knob or bump cap, what ever you prefer to call it, that I can buy to run the .095 line on it ?? Is it as easy as taking the bump cap into Home Depot or Lowe's and match one up ??
UMWolve is offline   Reply With Quote
Old 03-25-2012, 11:58 PM   #2
A Little Of Everything
Rewards Points: 1,364
I'm not sure why you'd want to use .95 line on that. But anyway...
I'd suggest you drill the hole in the head just a little larger. Depending on how the spool is made, you made need to drill a larger hole or two in that.
DrHicks is offline   Reply With Quote
Old 03-26-2012, 12:26 AM   #3
Registered User
Rewards Points: 5,204
Maybe not quite that large a string: http://www.weedeaterfeatherlite.com/trimmer-line
If drilling out for larger, remember the metal grommet (if used) may be useless and the plastic left will elongate from use because the string is bent-back on itself through normal use.
Gary
Weed Eater Problem tucker0104 Landscaping & Lawn Care 5 03-30-2012 01:10 PM
Weed eater repairs - carburator cellophane Tools 8 10-19-2011 07:28 PM
Weed Eater string keeps breaking? mhp8982 Landscaping & Lawn Care 6 06-04-2011 07:01 PM
Toro weed eater help! walterbell Landscaping & Lawn Care 0 07-26-2010 08:45 PM
Weed Eater Weed Wacker Prob bobo Automotive Repairs 7 08-18-2008 12:12 PM
