Chainsaws?? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-21-2012, 10:25 PM   #1
"Old" Newbie
Rewards Points: 177
Chainsaws??
Not sure if this the proper forum, but you folks have been so helpful in the past that I had to give this one a try.
I have a Husqvarna 350 chainsaw, 4 years old but only run about 10 hours. (Maximum)
It's started leaking bar oil (after sitting for several months I found several ounces in the bottom of the carry case.
Since it's out of warranty I'm wondering if I just take it to a shop or if this might be a relatively easy project for a mechanically inclined old graybeard with little experience working on saws, but success with replacing the rear axle wheel bearing on my lawn tractor. (Just to give you an idea.)
Advice and suggestions greatly appreciated.
Thanks. Again. Rob
RCrosby257 is offline   Reply With Quote
Old 05-22-2012, 07:17 AM   #2
Rewards Points: 6,652
Most of them will leak bar oil when sitting. That is why you drain it as best as you can. My Stihl 180 does it when in the case. Just the nature of the beast.
Old 05-22-2012, 04:09 PM   #3
"Old" Newbie
Rewards Points: 177
Chainsaws
Thanks, Greg,
Interesting. It had been sitting for about 6 months. I'll clean it up, dry it off, top it off, and keep an eye on it this summer as I use it intermittently.
See if it seems excessive or not.
Rob
Old 05-22-2012, 04:14 PM   #4
Too Short? Cut it Again!
As mentioned, they do tend to leak bar oil. This doesn't mean a seal, o-ring or something has not failed. I would see if you can find a parts explosion online. If it is a simple seal it should be no big deal to fix if you can work a hand tool or too. I was a PMT for Sears for awhile and never found chainsaws to be too daunting.
Electric chainsaw - is this a good idea? CoconutPete Landscaping & Lawn Care 21 07-24-2010 06:58 PM
