#1 |
chainsaw repair
Has anyone ever replace the starter spring on a chainsaw? Poulan is the brand.
#2 |
the Musigician
chainsaw repair
I have.... why? Is this a survey?
DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes! |
#3 |
chainsaw repair
I was looking for specific tips on how not to unwind the spring when you put it back in the cover with the cord spindle.
#4 |
the Musigician
chainsaw repair
Go to a repair shop and see if they have a used cord unit. You'll just unscrew the old unit and slip on the new/used one, the spring will not enter the picture. Easiest way, and you won't get cut up when that spring explodes.....
DM
#5 |
chainsaw repair
I have already gotten the spring and put it into the housing. I'm just not sure on how to get tension back on the pull cord so it will recoil after it is pulled from the housing. The starter just spins freely in there right now. Will the spring catch if I just rotate the starter in the direction of the recoil until it maxes out?
#6 |
the Musigician
chainsaw repair
It should, if not, can you take a pic or two to show what you're dealing with? That always helps here. Po)
DM
| Display Modes | |
| $1440+ labor only repair on 3 yr. old Goodman unit!?! | JMK | HVAC | 23 | 05-06-2012 11:45 AM |
| Choosing a Refrigerator based on Repair Value | 1655graff | Appliances | 5 | 03-01-2011 09:49 AM |
| Repair Compounds | saggdevil | Painting | 3 | 04-25-2010 04:02 PM |
| What do you guys think of this roof repair job? | darsunt | Roofing/Siding | 7 | 08-21-2009 09:43 PM |
| Ceiling Drywall Repair Question | kennykenny | Building & Construction | 6 | 12-30-2007 10:18 AM |
