Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 03-31-2011, 12:40 PM   #1
Chainsaw Bar Oil
Is there a motor oil I can use in a pinch???
pjordan4477 is offline   Reply With Quote
Old 03-31-2011, 01:23 PM   #2
Chainsaw Bar Oil
I don't know but, probably similar reasons as for not using motor oil in the transmission; it's different. Most chainsaws have had automatic oilers for a long time, so how is the pump going to handle motor oil? What about the seals? Will it stay on the bar, or is it going to simly be sprayed all over everything around you? What about lubricity? It seems like it would smoke pretty bad. Again, I don't know, but there are a few things that immediately come to mind.
Old 03-31-2011, 02:08 PM   #3
Chainsaw Bar Oil
I think in a pinch regular motor oil will do just fine, 10W30, 10W40. I've used it frequently.
NancyNGA is offline   Reply With Quote
Old 03-31-2011, 02:09 PM   #4
Chainsaw Bar Oil
My friend uses motor oil in his chain saw. I tell him not to. I don't know for certain that he's causing harm, but it seems likely -- bar oil is a lot thicker.
My father in law ties the bar oil to the pre-mix gasoline with a 3' rope -- then you're never in a pinch. Makes it easy to carry too -- hands free over the shoulder.
pyper is offline   Reply With Quote
Old 03-31-2011, 03:19 PM   #5
just a tool guy
mickey cassiba's Avatar
Chainsaw Bar Oil
I've done it "in a pinch", but I wouldn't recommend it for full time use. Try to find a non-detergent 30 wt...but by the time you find that, you probably could've found bar oil.
Mickey
One of these hammers will fix it.
mickey cassiba is offline   Reply With Quote
Old 03-31-2011, 03:22 PM   #6
Chainsaw Bar Oil
You want to use a much thicker oil than motor oil. A 75w90 etc gear oil would work in a pinch but like others have said there is a reason they make specific bar oil
Brodeurman69 is offline   Reply With Quote
Old 03-31-2011, 04:18 PM   #7
Chainsaw Bar Oil
The pinch is being out of one and having the other on hand.
Old 03-31-2011, 05:57 PM   #8
just a tool guy
Chainsaw Bar Oil
Been there many a time my friend...I doubt you'll burn it up on a one time deal, but as mentioned above, it could get a little messy.
Mickey
CHAINSAW, which to buy. pl1338 Tools 16 12-31-2010 10:10 AM
age of my stihl chainsaw keith gehring Landscaping & Lawn Care 2 10-02-2010 07:50 PM
Chainsaw help Navyman1 Tools 5 06-03-2010 11:45 PM
Chainsaw sweetwaters Tools 9 06-08-2009 01:34 AM
Gears of War Lancer Chainsaw Spac3Monkey General Discussion 2 06-13-2008 01:45 PM
