Chain Saw - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-31-2008, 11:28 AM   #1
Rewards Points: 82
Angry
Chain Saw
I hope I am in the correct forum?
I have a Poulan Pro 20" chain saw. Model PP295. Version "3". 46cc. Ser. # 02071D300274-3.
Poulan says that I cannot adjust the carburetor myself, that it must be done by a certified service center due to EPA rules. I know this is bunk. Is anyone familiar with adjusting this carburetor? Or does anyone know of a web site for helping individuals with small engine repair. Any feedback would be great. I am a member at the electrical forum and thought this may be a good place to start. I can't see paying someone to turn a screw 1/4 turn.
Thanks a bunch........John
Old 04-02-2008, 01:18 PM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
All I know about adjustment is mine has an H screw and an L screw plus an third screw labeled something else and it is the idle adjust.
I go to the chainsaw section of arborsite for all my chainsaw questions.
http://www.arboristsite.com/forumdisplay.php?f=9
Might I suggest to also post why you think your carb needs adjusting. What symptoms are you experiencing, etc. Those guys will ask you anyway before they tell you to go turn some screws.
Brik is offline   Reply With Quote
Old 09-29-2009, 07:26 PM   #3
Don't know it all, yet!
There is usually two adjustments to make, a low speed and a high speed.
No, there are three.
Excellent suggestion!
But, while I'm here:
Adjust the idle speed to close to what it needs to be.
Adjust the low speed mixture. This effects the idle speed but it is not the same thing.
Re-adjust the idle speed.
Adjust the high speed mixture.
Final check on the idle speed.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 09-29-2009, 08:18 PM   #4
I have had two Poulan chain saws for a number of years and never had to adjust the idle or mixture adjustments. I think this would be a last ditch effort. I would try changing the spark plug and clean up the air filter first. Is it possible some dirt etc. has entered the fuel tank and is restricting the fuel line. If the fuel mixture is off and is corrected there should be no need to adjust the idle speed, as it was set in the proper place before. Another thought, is your fuel-oil mixture correct for the engine?
Chatter is offline   Reply With Quote
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 07:02 PM
Snowblower Drive Chain Larryonthebay General DIY Discussions 10 12-20-2008 03:27 PM
What to use to lubricate garage door chain? JayBird General DIY Discussions 7 09-08-2007 07:09 PM
Chain link problem? jeremylindquist Landscaping & Lawn Care 1 06-24-2007 07:34 PM
pull chain switch bobo Electrical 2 12-28-2005 06:16 PM
