Chain Link Fence Post Removal - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-04-2007, 10:13 PM   #1
chain link fence post removal
I need to remove the metal posts to make way for my new cedar fence.
All I want to do is cut the existing metal posts even with the ground. Can i use my Sawzall with a special metal cutting blade? or should i buy a portable metal grinder? any thoughts?
thanks!
designman20
Designman20 is offline   Reply With Quote
Old 07-05-2007, 07:28 AM   #2
How many posts do you need to cut?
A sawzall will work.
You may need a few blades depending on how many posts that you have to cut.
redline is offline   Reply With Quote
Old 07-05-2007, 09:31 AM   #3
I think a sawzall would be easier than a grinder for that job. You'll need long metal-cutting blades. Get a handful of blades to keep the job moving along.
NateHanson is offline   Reply With Quote
Old 07-05-2007, 10:52 AM   #4
Rewards Points: 264
Don't forget, the new fence will have to be moved a little to allow for the old concrete footings. Dont plan on any grass growing where the old footings are.
Jeekinz is offline   Reply With Quote
wood fence post farrington135 Building & Construction 11 05-17-2011 03:32 PM
"T"-ing off of neighbours' fence? curls00 Carpentry 6 01-10-2009 04:39 PM
Chain link problem? jeremylindquist Landscaping & Lawn Care 1 06-24-2007 07:34 PM
Fence Post question JEB Carpentry 4 05-25-2007 04:06 PM
Fence Post Problem cdubim Building & Construction 3 03-12-2007 02:09 PM
