Cement Work - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-24-2008, 05:52 AM   #16
the Musigician
DangerMouse's Avatar
my kids and i put down 30, 40 bags a day by hand. it's not that big of a thing. by yourself it would be harder, yes. find a helper.
DM
Old 11-24-2008, 07:18 AM   #17
Rewards Points: 6,652
Instead of renting the cost of a mixer, purchasing of the mix, call a few Concrete finishing companies, and you will find that the cost for Time & materials will be less then you doing it, plus it will be done correctly the first time.
Old 11-24-2008, 07:43 AM   #18
the Musigician
boy, not around here it isn't cheaper! i called around looking for 'load ends' even, still much cheaper to do it myself with a wheelbarrow.
DM
Old 11-24-2008, 01:21 PM   #19
The pour will only last a year at best, and look like crap within the first couple of months.
Old 11-24-2008, 01:28 PM   #20
Why is that?
jerryh3 is offline   Reply With Quote
Old 11-24-2008, 03:40 PM   #21
bradnailer's Avatar
When I've had a pour like that, I've just had a truck bring redimix. It makes it a ton easier. The problem with trying to mix bags is that the first batches start setting up before you are 1/8th of the way through. I'd suggest you swing by some places where they are doing construction and watch them do some pours. Concrete work isn't hard, but it takes a little practice to get it to look decent.
bradnailer is offline   Reply With Quote
Old 11-24-2008, 04:00 PM   #22
freshman
Pipeline's Avatar
Yea I've seen that kind of stuff b4 bradnailer
The finished product of a clean, smooth concrete upon completion is really awsum.
I'm gonna dig info and screen more options before any cemet hits the ground
Pipeline is offline   Reply With Quote
Old 11-24-2008, 06:11 PM   #23
Originally Posted by jerryh3 View Post
Why is that?
My grandfather used to pour concrete, and always would he either order by truck regardless of the port if a yard or greater, or have enough guys to mix and pour continuously. One or two people, especially someone who has never done it cannot do it properly with Pre-mix. To do it properly, you need to order Sand, Lime, Cement for the size of the pour, or just pay less and let the experts do it.
Old 11-29-2008, 08:06 PM   #24
usually a truck won't even deliver one yard unless you piggyback on someone elses load. you will need a mag, trowel, edger, rake,water, a compactor, shovel, bullfloat, broom, boots, board to screed it. probably another set of hands. it is best to do it with someone who knows what's going on the first time you do it then can see what is up. i would do a four inch though. i would anchor it to the existing concrete though with some rebar and a hammer drill first. get grass up can produce gasses under concrete. compact within inch or so then scrape to the four inch point under your board you will use as a screed for a guide. put a small pitch in and you should only have to score it once down the center for that small of a piece. snap lines and do a good job. it will be there for a while.
chad4290 is offline   Reply With Quote
Can a homeowner perform electrical work in MA? dpd512 Electrical 77 04-11-2012 06:48 AM
Does your job require a permit? housedocs General DIY Discussions 203 12-01-2010 07:28 AM
Is it right that an owner must be licensed to perform work joey b Electrical 45 12-16-2008 10:16 AM
duct work framing kama Carpentry 4 11-15-2008 12:40 PM
Properly Sealing HVAC Duct Work craymer45 HVAC 5 11-06-2008 08:47 PM
