Cement Work - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-23-2008, 09:33 AM   #1
freshman
Pipeline's Avatar
cement work
hello
got a project in mind
I want to add an extenstion cemet to my standard concrete slab that came with the new house.
It would prolly be ways cheaper to DIY
I need to add 8 more feet in width by what 11 feet or so
I have exact numbers somewhere
joint expansioners in between the new cemet [like say in the middle at 4 feet and between new and old cemet] is what I hear to prevent crack.
I have a home depot book
Getting info here to match will be great to build confidence to start
I prefer premix [just add water I hear]
What tools I MUST have
Also, how can I be certain of the grass that is to be removed is ideally flat to lay the cemet on..
any help is great
Pipeline is offline   Reply With Quote
Old 11-23-2008, 02:36 PM   #2
freshman
Pipeline's Avatar
bumping
Old 11-23-2008, 03:53 PM   #3
Rewards Points: 6,652
Need to figure if you want it 4", 5" or 6", and what the cubic yards are. As for premix, better to go with a truck, due to you are talking around 1.08642cu yds for 4" slab, 1.35802 for 5", 1.62963 for 6".
http://www.concrete.com/calculatorsmaterials.htm#volume To do it old school http://www.ehow.com/how_2266389_calc...paign=yssp_art
Old 11-23-2008, 04:01 PM   #4
freshman
Pipeline's Avatar
have no idea about cubic yards none
I tape measured it an extra 8 feet I need to cover where the grass is. The existing slab was there with the new house.. that slab is fine but have a back door with a 2 by 2 feet of cemet in step with the backdoor that is 8 feet away from slab.
so instead of 20 feet wide cemet I want an extra 8 feet to cover the entire width of screen door patio and back door patio with no grass between it and replaced with cemet
this way I have the platform to put up a screen enclosure to my wants and needs.
Cubic yards I'm thinking you saying that for cemet volume, right??
Old 11-23-2008, 08:34 PM   #5
See prev. links. Concrete is measured in Cubic Yards, so that they know how much to order on the truck when it is delivered. You take the Width x the Length x the thickness all in inches. So, you would have to convert everything from feet times 12 for the dimensions all in inches. As for the depth, you divide by 12 for the decimal conversion. If you did not do well in basic math, the two links I prev. posted help.
Old 11-23-2008, 08:38 PM   #6
freshman
Pipeline's Avatar
yea ok I understand
basically you think 8 feet width by 11 feet plus say 3 inches thick needs a truck???!!!!
holy smokes!!! It not a lap pool I'm putting back there - no offense....
Old 11-23-2008, 08:51 PM   #7
the Musigician
DangerMouse's Avatar
you need a hose, wheelbarrow, trowel, hoe and shovel + about 40, 50 bags of premix and an attitude adjustment.
DM
Old 11-23-2008, 09:11 PM   #8
freshman
Pipeline's Avatar
40 50 bags!?
I'm just being funny dangermouse - don't take me wrong, I'm a nice guy.
I have a sense of humor that's all
but facts are this is real stuff we're talking here and I hear all of you guys
I knida thought that premixed bags and the odds and ends could [wasn't so sure] be enuff
just wasn't sure a mixing truck was needed.... those things I see for filling out pools
No offense to anyone here
Old 11-23-2008, 09:20 PM   #9
If it's only a yard and you have access to a truck you can get the cement at a "u-cart" place.
jerryh3 is offline   Reply With Quote
Old 11-23-2008, 09:27 PM   #10
freshman
Pipeline's Avatar
A pick up [personal truck] then is what people are meaning here??
The truck to cart around the cemet machine??
I'm a freshman to these things - seen'em [the cemet machine]but not use'em
Sounds like I'm gonna have to be a self made man here with whatever help[info] I can get here, books, you tube and store workers.
Old 11-23-2008, 09:40 PM   #11
the Musigician
yes, that area will take approx. that many bags.
DM
Old 11-23-2008, 09:40 PM   #12
Yes. A pickup truck. Something like this:
http://tomballrental.com/serv01.htm
Old 11-23-2008, 09:59 PM   #13
freshman
Pipeline's Avatar
now we're really getting somehwere with the cart system
1 yard=40 BAGS [that is what the website say]
So I need apx 8 feet so that's close to 3 yards
40 times 3 is 120 bags!
cart system seems less labor less cost
I I
Plus I would have to factor in the 11 feet in the other I____I side
I'm starting to think this may be beyond my skills as a one man show as I would also need joint expansions to prevent crack
Old 11-23-2008, 10:30 PM   #14
Kap
Mowing my life away.
Not sure how you get 3 yards out of 8 feet or where the 120 bags come from.
8 feet x 11 feet x .25 feet (3 inches) = 22 cubic feet. There are 27 cubic feet in one cubic yard, so 22 divide by 27 = .81 cubic yards. A 60 pouind bag of ready mix will give you approximately half a cubic foot, so you will need about 44 bags.
That's a lot of cement to mix by hand in one day. And a very expensive way to do it with that kind of quantity. If you don't have a pickup truck, you could probably rent one and a portable mixer and buy your sand, cement and aggregate seperately to mix your own concrete and still save money over buying premix.
Kap is offline   Reply With Quote
Old 11-23-2008, 10:34 PM   #15
I I
It is a little ambitious for your first concrete project. You will most definately need help with the screeding and finishing. Start with a small sidewalk and practice the skills. Concrete is too expensive not to get it right the first time.
Can a homeowner perform electrical work in MA? dpd512 Electrical 77 04-11-2012 07:48 AM
Does your job require a permit? housedocs General DIY Discussions 203 12-01-2010 08:28 AM
Is it right that an owner must be licensed to perform work joey b Electrical 45 12-16-2008 11:16 AM
duct work framing kama Carpentry 4 11-15-2008 01:40 PM
Properly Sealing HVAC Duct Work craymer45 HVAC 5 11-06-2008 09:47 PM
