Cement Filled Chain Link Fence Posts - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-06-2011, 12:46 PM   #1
Cement filled chain link fence posts
I installed a batting cage that came with ground sleeves for 1 5/8 16 gauge fence post. The installation went fine but I live in West Texas where the winds get very strong and during our first strong wind storm (40-50 mph) the posts buckled mostly just above the ground sleeves. Since the ground sleeves are cemented in place and can only take the diameter mentioned above, my question is can I fill galvanized fence posts with cement to make them sturdy and withstand the strong winds?
johnrdz is offline   Reply With Quote
Old 02-06-2011, 01:56 PM   #2
Rewards Points: 1,452
It seems to me that a post "only" 1-5/8" in diameter is marginal to begin with so I am not sure whether filling them with concrete will completely solve the problem.
You would get some added strength by filling them with concrete.
Part of the added stiffness comes because in order to be bent or pushed over they must get squashed or they must crack like an egg. The concrete filling prevents squashing and the steel post itself is quite resistant to cracking like an egg.
Can you use a mesh with larger holes, say 2-1/2 inches (less wind resistance as well as lighter weight)? Can you get posts with thicker gauge metal and that still fit?
Old 02-06-2011, 02:12 PM   #3
Concrete & Masonry
Rewards Points: 536
Yes you certainly can. Pick up a bag or two of "quikrete", mix it wet, pour it in using a funnel, and you can even add a small diameter rebar (like 3/8") for added measure. At some point though, the ballast in the ground will become the weak point.
jomama45 is online now   Reply With Quote
Old 02-06-2011, 08:32 PM   #4
thanks
Thanks for the responses. Although I cannot use a mesh with larger holes I think I will fill with concrete & rebar in lieu of a thicker gauge.
Tags
batting cage , cement filled , concrete filled , filled fence posts , withstand winds
Cedar or PT Fence Posts??? C&D Landscaping & Lawn Care 15 04-08-2008 11:27 PM
Fence Posts - Sonotubes? AaronBerquist Building & Construction 20 07-25-2007 12:24 PM
chain link fence post removal Designman20 Landscaping & Lawn Care 3 07-05-2007 10:52 AM
cementing fence posts? cambece Building & Construction 4 09-06-2006 10:54 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
