Cargo Trailer Floor - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-21-2013, 09:45 PM   #1
Rewards Points: 155
cargo trailer floor
I bought a used cargo trailer- 6' x 10' to tow equipment in. The floor looks like 3/4" plywood but looks to be worn- the metal beams under it look to be in good shape. I am wondering how difficult it is to remove the old plywood and install new plywood. ANy advice-suggestions? Looks like it's all screwed down to the metal beams- i am not sude what type of screws are used
Huskyfan68 is offline   Reply With Quote
Old 07-22-2013, 06:49 AM   #2
Rewards Points: 12,814
Need a picture.
May be easier to just add another layer of 1/2" subfloor rated plywood over what's there.
Is this an enclosed trailer?
Lowes and Home Depot both carry self tapping flat head screws just for this job.
I've found they hold better if I predrill a hole instead of letting them self tap.
Old 07-22-2013, 09:10 AM   #3
Rewards Points: 155
thanks Joe- I will snap a picture- I thought of that but my concern is- if the original plywood is worn around the outer edges- won't that eventually deteriorate?
Old 07-22-2013, 09:23 AM   #4
Rewards Points: 6,652
Yes it will. Some people use Marine grade plywood, then coat with a couple coats of poly on both sides, before installing, to help make it last. As for around the edges, you could use metal bead around them, to help survive any damage.
Old 07-22-2013, 12:43 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
A few years back I built a little teardrop camper, sealed the bottom of the plywood with roofing sealer with fiber. It never leaked the first time and is still like new. It is a little messy but worth it. If you plan to leave the old floor down it may be a little harder to seal the bottom in place.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 07-22-2013, 03:43 PM   #6
I just put together a trailer from Harbor Freight and used 3/4 Plywood with a few coats of external Polyurothean. Seems to have worked well. Just make sure you poly after you drill the holes to ensure you don't get rot around them, due to trapped water.In addition, I know of people that have used Plasti-dip around the screws and other areas to give it a seal, as well as grip when walking on it.Good luck with your trailer.
BRWhelan is offline   Reply With Quote
The Following User Says Thank You to BRWhelan For This Useful Post:
BigJim (07-22-2013)
Floor joist replacement and reconfiguration WillK Carpentry 2 09-01-2011 09:01 AM
Pet Sanctuary Needs Urine-proof, affordable floor which is not too hard. Pet Sanctuary Flooring 1 05-31-2011 05:53 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 05:58 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 08:45 AM
