Can't Turn Valves On Febco 765 For Sprinklers - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-31-2012, 06:30 PM   #1
Can't turn valves on Febco 765 for sprinklers
I had my sprinklers blown out in the fall, now that the weather is nice it's time to get the sprinklers going.
Except when I tried to open the valves on the backflow preventer (Febco 765), they won't budge!
Here's a photo (sorry it's so blurry, I was crawling under the porch and supporting myself with one hand ):
It looks like it was winterized properly - the ball valves are turned 45 degrees. But neither of them will move. I tried taking the handle off and turning it with a pair of channel locks, but still nothing.
Meanwhile, my lawn is drying out.
Any ideas on what I can try to get these valves to turn?
thinksincode is offline   Reply With Quote
Old 06-01-2012, 10:29 PM   #2
Too Short? Cut it Again!
Try WD 40 first. If that does not work, Liquid Wrench should.
Old 06-05-2012, 08:37 PM   #3
Can you cut the supply to them for a few minutes or are they your last line between the system and your home water? If you can cut the pressure off, go turn on some heads and then try once all the pressure bleeds off. I have used hammers and longer pipes with success to but be careful.
RegLearning is offline   Reply With Quote
Tags
sprinklers
Cant turn shower nob to turn on shower GeoffStone Plumbing 5 04-25-2012 08:09 AM
Switch crossed? Turn on one, a different one goes off... no1hustler Electrical 64 02-23-2012 10:25 AM
Turning off valves bathroom sink richard7994 Plumbing 3 11-28-2011 05:25 PM
Soldering 1/4 turn valves Manuel6 Plumbing 2 12-11-2006 02:32 PM
Faucet won't turn off etiger Plumbing 1 08-31-2005 02:46 AM
