Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 05-02-2012, 06:34 PM   #1
Can I run irrigation PVC pipes along the fence?
I need to run two PVC pipes to the other side of the yard. In between I already have lawns, planting boxes, patios etc so it will be a PITA to run the PVC pipe underground. But then I found out that if I can run my PVC pipe along my fence (I have 6' tall solid fences between me and all my neighbors.), it will be a very simple job. My fence was painted Boston Green and I can paint my PVC pipe the same color so that it will be barely noticeable.
What is your take on this?
htabbas is offline   Reply With Quote
Old 05-02-2012, 10:24 PM   #2
Well freezing isn't an issue for you...
Were you planning something permanently connected to your plumbing or something you could maybe attach to a convenient hose bib when needed?
Evstarr is offline   Reply With Quote
Old 05-03-2012, 12:14 AM   #3
It never freeze here in California.
I am planning the PVC pipes to be permanent. Once it reaches the other side of the yard I will route it into the ground for the sprinkler head.
Old 08-13-2012, 11:05 AM   #4
Special User
Don't forget a backflow preventer / vacuum break. Also, attaching permanent plumbing to a home / water meter requires a permit or licensed plumber in many jurisdictions.
Also, bare white PVC turns brown in sunlight and becomes very brittle. PVC requires UV protection, usually done by burial but paint should also work if you repaint whenever it flakes off.
tylernt is offline   Reply With Quote
The Following User Says Thank You to tylernt For This Useful Post:
sdsester (08-14-2012)
Old 08-14-2012, 07:58 AM   #5
sdsester's Avatar
Definitely mind the UV degradation warning. You may want to step up from Schedule 40 to Schedule 80 if you are going to lay it out in the sun. The added thickness will better resist the UV damage. It would be a bit more expensive but you might eliminate the risk by running galvanized pipe for the supply lines you need until you can go underground again.
Painting PVC can be a challenge. Rustoleum makes a plastic primer I would encourage you to try. It comes in liquid and rattle cans. Rustoleum also makes plastic paint in rattle cans. Krylon Fusion, in rattle cans, is formulated for plastics also.
Make sure you put some sort of cut-off on those supply lines so you don't have to shut all the water to the house off if something goes wrong. You definitely need backflow and anti-syphon valves on it too.
sdsester is online now   Reply With Quote
Reuse Concrete Fence Post Pier & Fence Post Extraction JasonCA Landscaping & Lawn Care 2 03-24-2012 09:58 PM
How to add a dividing fence to chain link fence and house with siding catburke Building & Construction 0 09-20-2010 02:39 PM
Largest Crown Molding Cut on DeWalt 716 Klawman Carpentry 8 11-14-2009 09:05 PM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 10:03 PM
"T"-ing off of neighbours' fence? curls00 Carpentry 6 01-10-2009 04:39 PM
