Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 01-18-2007, 09:50 AM   #1
Question
Bush Hogging?
I think it's called that...
Anyone know of an affordable trail cutter...something to easliy get rid of brush. I was looking into a Swisher brand...that's all I could find.
K&G's Cabin is offline   Reply With Quote
Old 01-18-2007, 10:48 AM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Bush Hogging?
Another
http://www.drpower.com/TwoStepCatego...=2&src=IP00028
Depends if you want one to be pulled behind a tractor or ATV or a walk behind. Swisher makes both. DR makes walk behind.
The pull behind ones from swisher have a separate motor for the cutters. My FIL has one of these
http://www.deere.com/en_US/ProductCa...r=1130LV&tM=GC
Its uses a PTO from his tractor to power it.
Then of course you have the chainsaws and things like this
http://www.usa.husqvarna.com/?url=%2...frames%3Dfalse
I too want to cut some trails this summer. I was thinking of renting something like the DR after I cleared the big stuff with the chainsaw. I may also need a backhoe due to terrain issues. I have about a mile or so to do.
Brik is offline   Reply With Quote
Old 01-18-2007, 12:44 PM   #3
Bush Hogging?
Oh yes, I saw that one too. I don't know how much it is though. I am looking for the kind you walk behind and not pull. Swisher has one that retails at about $1200. I guess that is the going rate.
Old 01-18-2007, 01:04 PM   #4
Handyguy
Brik's Avatar
Bush Hogging?
DR's are $1100 and up.
Old 01-18-2007, 01:05 PM   #5
Handyguy
Brik's Avatar
Bush Hogging?
http://www.drpower.com/TwoStepModels...tep&LinkType=3
Old 02-25-2007, 10:04 AM   #6
Bush Hogging?
Greetings--
I rented a walk-behind brush mower, similar to the DR and others. It worked like a champ !! Cut through brambles, small brush and trees like I was mowing the lawn (ok ok .. kinda....). It had metal blades, not the string thingies.
Check the rental places. I had to call around to several before I found one that carried these beasts.
As much abuse as these things can take when mowing, I decided to rent one a few times, rather than tear up one I owned :-)
Piney is offline   Reply With Quote
Did the bush cause the damp? atomicpig General Discussion 9 02-13-2007 08:00 PM
