Burying Downspout Extentions - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-13-2014, 08:41 PM   #1
Hvac pro
Rewards Points: 41
burying downspout extentions
I want to bury my downspout extentions and bring them away from the house can't exit to day light. How should I terminate? Dig a shallow hole and fill with stone? Use a grate of some sort. I want to stay away from pop ups bc of the possibility of freezing in the winter. Will it drain if the pipe has to 90 up to daylight?
aa7483 is offline   Reply With Quote
Old 04-13-2014, 10:23 PM   #2
Rewards Points: 216
i have one, the PO's installed it. it freezes in the winter. i disabled it.
Fix'n it is online now   Reply With Quote
Old 04-13-2014, 10:29 PM   #3
Rewards Points: 12
I have mine buried with a 90 up capped with a grate. As long as the inlet is higher than the outlet it will work. You will need to clean out the 90 on occasion.
If you live where the ground freezes you might want to use perforated pipe so water does not get trapped in the pipe. Wrap the pipe in landscape fabric to keep the soil out.
Dan
djlandkpl is online now   Reply With Quote
Burying downspout above frost line RegLearning Roofing/Siding 1 01-20-2013 08:51 PM
Should I add a downspout? scottyv81 Roofing/Siding 5 05-09-2012 08:37 PM
Water Overflow from Downspout Drain Nospammer Building & Construction 1 10-04-2011 05:18 PM
Downspout over lower roof smcclana Roofing/Siding 5 10-08-2010 01:20 AM
Replacing patio - Relocate downspout slvrbullet98 Landscaping & Lawn Care 2 05-08-2009 09:30 AM
