Burning Bush - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-26-2010, 02:22 PM   #1
Rewards Points: 640
Burning bush
How exactly do you care for and prune burning bushes? I have a very long row of them they made into a hedge.. and they are overgrowing some and two of them just look like they dont want to grow or might be dead (not sure how to tell) any suggestions?
BlueBSH is offline   Reply With Quote
Old 03-26-2010, 02:50 PM   #2
the Musigician
DangerMouse's Avatar
Is it talking to you? If not, grab a fire extinguisher!
OK, sorry..... I couldn't resist.... I have no idea. But someone here does, I'm sure.
DM
Old 03-26-2010, 03:12 PM   #3
http://www.tlehcs.com/Question%20of%...urningbush.htm
cellophane is offline   Reply With Quote
Old 03-26-2010, 03:36 PM   #4
Rewards Points: 640
DM
Well it did tell me something about finding the promised land in the large house next door... so I'm not sure
Old 03-26-2010, 04:01 PM   #5
the Musigician
-=chuckle=-
sorry
DM
Old 03-27-2010, 01:23 AM   #6
I'm sorry but I don't have the answer to your question but I am very interested in burning bushes. I am a new home owner and have zero landscaping experience, lol. I have heard that they are quite easy to care for.
I was thinking of putting some directly in front of my house behind an edger with some pretty flowers in front. I'm unsure if this would be a good idea. I'm torn between the burning bush and boxwood. I just think burning bushes are so beautiful!!! Hope you get the answer to your question.
skittlebear is offline   Reply With Quote
Old 03-27-2010, 06:31 PM   #7
GardenConcepts's Avatar
Rewards Points: 150
other than lighting them on fire.... Burning Bush can be pruned now. If you must use hedge shears, thin out the inside with hand pruners when you finish with the shears. The shears leave the plant with tight growth on the outside and nothing on the inside. If you selectively thin the shrub to let light into the center of the plant, you'll get more growth on the inside.
Burning Bush- even compact Burning Bush, gets about 8' tall and wide, so space accordingly and you won't have to prune as much. As long as they aren't in soggy soil, they are pretty much carefree. This plant is considered invasive in most states.
GardenConcepts is offline   Reply With Quote
Old 04-03-2010, 09:26 AM   #8
Be careful of the shearing effect which will cause witch's brooms. The end of the plant will have 3, 4, or five shoots coming from one branch. Looks like a broom. Sounds like yours are good size already. Perhaps thinning them out, maybe remove every other one. They are not meant to be hedged. Like garden Concepts said prune the interior as well. They need to look pretty when the leaves fall off too!!
Skittlebear- Burning bushes are beautiful just do the research on the pruning. If you want more of a hedge then by all means use the boxwood. They are evergreen as well. I like both. I just find the boxwood a little more formal. Depending on your pruning style of course. i would venture to say the boxwood will be a little tougher to establish than the BB
Bushman is offline   Reply With Quote
Been looking at some Wood Burning Stoves SELLC HVAC 17 10-20-2009 10:06 PM
Home made wood burning furnace JustinK HVAC 14 10-05-2009 09:26 PM
Burning Bush problems/questions sk8z Landscaping & Lawn Care 1 02-14-2008 01:28 PM
Gas Furnace - Burning smell at return blakemcginnis HVAC 4 01-26-2008 09:29 AM
Did the bush cause the damp? atomicpig General DIY Discussions 9 02-13-2007 08:00 PM
