Building A Storage Shed - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-22-2010, 06:21 AM   #16
steveel's Avatar
Even if you are pretty sure there is no buried utilities, call you version of MissDig before starting to move dirt (or incurring much other expense). They'll mark locate all the buried electrical and gas lines etc.
steveel is offline   Reply With Quote
Old 09-22-2010, 07:05 AM   #17
Rewards Points: 1,548
I recently built (from scratch) a ca 100 sf shed (8x12) with four cinder block feet at the corners. The shed sits about 8 inches, or the thickness of the blocks, above ground. In hindsight I should have had six feet in all, three along each 12 foot side. Some sagging has occurred halfway across the front even though I used double 2x6 rim joists. The blocks sit on slightly larger pads of tamped gravel flush with the ground and about 12 inches deep.
My city requires a permit for a shed of any size, and there are setback requirements.
More details: http://www.%43ockam.com/shed.htm
For a 10x15 shed, I would want at least 3 block feet from side to side and three block feet from front to rear. Putting the blocks along the perimeter under the rim joists is no problem but there needs to be support such as a center beam for the middles of all the joists, to keep any of the joists from sagging because it did not have a concrete block foot directly under it.
Or use 2x8 joists, and 8 blocks, 4 along the front and 4 along the back.
Old 03-22-2011, 10:42 PM   #18
Sheds
I found a 10x15 storage shed like you are looking for at http://www.shedsforlessdirect.com/ , it is actually a garage with double front doors and a side door. It's a vinyl shed so there isn't all the construction you have with wood sheds.
Storage_Sheds is offline   Reply With Quote
Preparing site for a storage shed DIY4EVER Landscaping & Lawn Care 3 01-01-2009 09:51 PM
Morning Pilgrims! Greenhorn looking for answers! - Need help building a Shed bazzbozz Building & Construction 3 11-11-2008 08:36 AM
Building rafters for small shed simonb Roofing/Siding 4 07-15-2008 12:32 PM
Building a shed, need help with pouring slab / fill ssybert Building & Construction 5 06-12-2008 06:19 AM
Painting the inside of a storage building MillerClemsonHD Painting 6 03-23-2007 07:23 AM
