Building Stone Base Around 4x4 - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-02-2013, 07:25 AM   #1
Rewards Points: 190
Building stone base around 4x4
I am going to upgrade my 4x4 post on my porch. I want a stone base about 3 feet high? and then I am going to make tapered column appearance on top to hide the 4x4.
What is the best method for the stone base?
1) Build out a boxed frame with 2x4, plywood, water shield, then cement board?
2) Cinder blocks?
3) Saw this method on tv. Stack pavers and use glue?
The post current sit on sonotubes. What would be the best method listed above? How high should I make the stone base dimensions of the box?
I have to pour a base around the sonotube. How thick should I pour my concrete pad & dimensions?
ryanb4614 is offline   Reply With Quote
Re: old buildings RWolff Building & Construction 157 01-19-2014 12:35 AM
Building column wrap with manufactured stone; need advice!. elcaminolee Concrete, Stone & Masonry 1 07-14-2013 05:40 PM
Set shower base in mud svaic00 Plumbing 2 06-06-2013 07:27 PM
What correct mix for building a stone foundation wall? & correct mix for stone fireplace. world travler Building & Construction 0 08-04-2011 06:39 PM
Stone foundation for a small shack andrgo Building & Construction 10 09-13-2007 01:49 PM
