Building Planter Boxes - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-15-2009, 04:12 PM   #1
kimberland30's Avatar
We have a 10' x 10' metal gazebo that shifts a lot because of wind storms. I had an idea to build L shaped planter boxes for each corner that would sit on the outside of the metal leg frames. The planters would only be wide/deep enough to hold a bulb of elephant ears and some annuals/perennials (maybe a max of 12" tall and 12" wide).
I got to thinking about how the gazebo moves, and was wondering if it would be feasible/sensible to screw the metal frame corners into the planter boxes. Or should I make the planter boxes square, and anchor the legs of the gazebo inside of it somehow? If I go this route, would I need to spray the legs with some sort of sealer so it doesn't rust from dirt/water?
Our gazebo is like the one I've posted here, and I was thinking of the planter boxes going on the outside of the legs.
kimberland30 is offline   Reply With Quote
Old 05-15-2009, 10:19 PM   #2
Difficult call.
If the boxes are outside the curtains hang in them, but if they are inside they take up valuable space.
Any kind of movement against a ground anchor will scrape off paint and start rust if they're not tight.
Try coating the attaching brackets with black plasti-dip first.
Stillwerkin is offline   Reply With Quote
Building Boxes around Vents/Pipes in Basement H Thomas Building & Construction 2 03-28-2008 10:55 AM
raised planter boxes la15ota Landscaping & Lawn Care 4 02-28-2008 04:26 PM
Building a Raised Planter Bed kashimama Landscaping & Lawn Care 4 11-07-2007 12:25 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
