Building A Hot Tub - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-04-2010, 03:20 PM   #1
Building a Hot Tub
Hi everyone,
For a while now I have been interested in building my own hot tub. I have tried to search for information on the web but there doesn't seem to be a great deal regarding building a hot tub from scratch. I'm looking to build one with probably a concrete block form, filled with concrete, and ceramic tile to finish it off. Has anyone done something like this? If so do you have any particular websites that I should check out? This is the only site that I have found with any real information: http://www.buildatub.co.uk/ and even it is missing a lot.
Thanks for any help you can give me.
Skimmy is offline   Reply With Quote
Old 03-09-2010, 03:30 PM   #2
I'll admit, I have never done anything like this, but it is a very interesting idea. From my HVAC and plumbing engineering perspective, I'd like to suggest an continuous fired hotwater heater with a small recirculating pump for the water heating and movement. Pipe it in line. You flip a switch, or use a timer to run the pump, and when the burner in the water heater senses flow, it fires the heater and heats the water to your desired temp, say 90F or whatever. If the water heater detects basically 90F coming back to the heater, the burner wont run and you're just circulating with a small, 1/10 hp pump then.
Would be interested to hear others discuss this.
Rhizzlebop is offline   Reply With Quote
Old 03-10-2010, 09:22 PM   #3
Skimmy, there doesn't seem to be much action here to get you any answers. Might I suggest you post your question over on Garden web forums as their typically is more action over there.
Old 03-11-2010, 12:21 AM   #4
Don't forget insulation!
My cousin built a nice stone & ferro-cement tub around some massive styrofoam blocks. It keeps pretty darn hot long after the heater is turned off.
Someone has to have written a book on this by now. If this an outdoor project you can also use foam blocks into the earth to create walls that will keep the heat from spreading out horizontally.
echase is offline   Reply With Quote
Advice on building a backyard studio/office? johnnyb10 Building & Construction 11 12-04-2011 12:43 AM
Building a temporary workshop inside of large pole building HandyDave Building & Construction 0 02-17-2010 09:39 PM
NEC uses building size?????? hhiibel Electrical 14 08-08-2008 01:19 PM
Building a movable garden shed/greenhouse gardener Building & Construction 1 06-13-2008 05:47 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 07:35 PM
