Building A French Drain - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-09-2010, 02:28 PM   #1
gruntman's Avatar
Rewards Points: 79
Building a french drain
I live in the NE and get a lot of snow.
I would like to put in some drains to move water away from my house and out of my yard before I put down some loam and grass seed. The first two images are of the left side of my house and the second two are of the right side of my house.
On the left, the water runs out of the gutter, travels along the side of the house, and across my backyard patio (which Im replacing). I also get alot of standing water in the front yard (soil is very hard packed with rocks and boulders) which eventually runs along the left side of the house as well. I thought I could put in a french drain to move the water away from the house. Does this seem like a reasonable solution?
On the right, I need to do something with the water so that the new dirt it doesnt get washed away with the first storm. Should I have the water enter a solid PVC pipe and move it to the backyard and then swith to perforated pipe and gravel?
Building a french drain-img_6114.jpg   Building a french drain-img_6115.jpg   Building a french drain-img_6118.jpg   Building a french drain-img_6117.jpg
gruntman is offline   Reply With Quote
Old 05-10-2010, 04:21 PM   #2
New Home Owner
With water coming out of the down spouts, I bought a length of non-perforated pipe, a length of perforated pipe. I then dug a trench under my lawn in almost a horse-shoe pattern (the length really doesn't matter as long as it goes away from your house...it all depends on how much digging you want to do). I attached the non-perforated pipe to the down spout and ran it in the trench until is was around 3 feet from the house. I then connected it to the perforated pipe for the remainder of the trench. Using a sock and gravel, I then covered the pipe before topping it off with topsoil and seed. My lawn on top of that pipe is the best grass on the entire property. It is almost the same idea of a French drain, but you don't have an output nor a bubbler at the end. If you get a lot of rain, you can also put a T connection between the perforated and non-perforated pipes so that if the water does get backed up for some reason, it comes up 3 feet away from the house rather then right beside the foundation. Make sure you put a rodent guard or a case and grill over the T connection, so you don't have animals/foreign substances getting into your drain. I would recommend this for both sides of your house, as with new dirt, you will probably be putting down new grass. This might not be what you are looking to do, but I did this and will do this in every house I own. In my opinion, it is much better than rain barrels!
Ontario Buckeye is offline   Reply With Quote
Old 05-12-2010, 08:53 AM   #3
gruntman's Avatar
Rewards Points: 79
In colder climates how far down do you need to dig when you put down the pipe?
I have seen perforated pipe at the box store that has some kind of peanuts wrapped in a sock around the length of pipe. Is that junk? am I better off doing the perf pipe crushed stone wrapped in cloth myself?
How do you deal with debris that comes down the drain pipe? Some type of catch basin installed near the beginning of the pipe? I dont want this thing getting clogged.
Old 05-12-2010, 09:38 AM   #4
New Home Owner
Well, I only went down about a foot and a half. It doesn't really matter how far you go, because it is your lawn. I have never used the pipe that you are talking about, so I can't make comment if it is junk or not. I have the cloth sock that I wrapped myself. As for the debris, it all depends on your surrounding area and your eave-troughs. I installed a piece of chicken wire at the top of my down spout, so that the big leaves don't even make it into the spout. For the little stuff, I have a little clean out that I cut into my down spout near the bottom. I cut a hole in my down spout that is about halfway through the pipe and about 6 inches in height. I cut it out using a jigsaw, but it really depends on the material of your eaves. Try not to mangle the piece you are going to remove...I used the removed piece as a cover for the hole. I inserted a piece of chicken wire and placed a piece of screening (from an old window) on top of it and secured both to the inside of the pipe, near the bottom of the hole. This collects all the little stuff that comes down without disrupting the flow of the water. If you have a lot of water coming down, you might want to use something a little less restrictive than the screening...possibly old pantyhose?. After my little filter was installed using a couple screws, I used the remove piece from when I cut the hole to make a door, so that it looked nicer. I had to cut the edges a little, but was able to have it so it is attached at 1 end and swings open and closed. I then used a little "hook" for lack of a better name to secure the door closed. It is barely noticeable and I only have to clean in out once or twice a year...usually around the fall. Here is a picture I found on-line that is similar to what I did
Old 05-12-2010, 10:16 AM   #5
Rewards Points: 89
Great discussion guys. I'd like to do this, as well.
tbeaulieu is offline   Reply With Quote
Old 05-12-2010, 11:12 PM   #6
drainage
Drainage is a tricky thing. We had a French drain system built in our last house and it worked great. Just make sure you look at the whole picture. I've seen people do French drains but not address basic grading issues, which can offset the water flow. Here's more on the whole drainage thing:
http://www.oldhouseweb.com/how-to-ad...basement.shtml
Allison1888 is offline   Reply With Quote
Old 05-13-2010, 05:16 AM   #7
Rewards Points: 89
Agreed. In fact, I've got dozens of hours logged this spring so far, regrading ... by hand. Ugh!
We had/have a number of raised mounds that someone installed in the front yard many years ago. In my view they trap the water between them and the house. In fact, there's even reverse grading at portions of the foundation. I'm removing the mounding, sloping the ground away form the house. To make it even more fun, there's are old tree stumps (one took 2.5 hours last night!) and a number of bushes that I'm removing (and their stumps).
Once I've got it all dug out I'll switch to drain mode. I'm also going by the water pattern's I observed earlier this spring and took pictures of.
Old 05-13-2010, 07:41 AM   #8
Rewards Points: 1,548
If you lay the drain pipes above the frost line then they could freeze up when full and just not function for awhile. You could get a big late winter rainstorm and the pipes are not thawed out yet and the result is simply as if you never installed the drain pipes in the first place.
Old 05-13-2010, 08:20 AM   #9
New Home Owner
agreed...you may have a problem once a year. I have never had that problem with mine...again, not to say you won't. If you put them below the frost line, you receive none of the benefits...you might as well just get a non-perforated pipe and take it all the way to the ditch or catch basin. Plus, digging a foot and a half deep trench (properly graded away from the house of course) is a heck of a lot easier that digging a 4 foot trench. Also, the layer of gravel doesn't need to be 6 inches think...2 or 3 should probably be enough to disapate the water and allow enough room for top soil and grass.
Old 05-13-2010, 08:30 AM   #10
Rewards Points: 89
Why do you say none of the benefits by burrying the pipe below the frost line?
One a new house, that's where they'd put it these days. Why wouldn't I want to a) install french drains near the footer of my foundation and b) bring downspouts into similar setups, albeit not quite as deep?
Old 05-13-2010, 08:58 AM   #11
New Home Owner
sorry, you get the benefits of proper drainage of water away from the house, but I worked mine into helping the lawn. Similar to Gruntman, I needed new dirt and new lawn and used the "wasted" water to build my lawn while moving the water away from the house. Gruntman seems more interested in his lawn drainage than his basement drainage. I am assuming that his weeping tile around his foundation is working fine and he is just trying to remove access surface water. I apologize for my choice of words and not clearly explaining the benefit I was referring to. I would definitely dig it down below the frost line if I was putting in drainage for the foundation. For downspouts, I use them as a sub-terrain watering system. No need for sprinklers when the water is already in the ground.
Old 05-13-2010, 09:24 AM   #12
Rewards Points: 89
OH! Gotcha!
Old 05-23-2010, 12:49 PM   #13
gruntman's Avatar
Rewards Points: 79
My property is slightly slanted and drops off at the end over a small hill with a top of boulders. There are houses below. If I build the french drain and run the perforated pipe and gravel along the back yard (see string) shouild I just end it at the fence? I could install one of those pop-up emiters at the end. The one thing Im concerned about with that is if I run it shallow enough for an emmiter to work it will just freeze up in winter.
Building a french drain-img_6121.jpg   Building a french drain-img_6119.jpg   Building a french drain-img_6124.jpg   Building a french drain-img_6130.jpg
Old 05-24-2010, 06:37 AM   #14
Rewards Points: 89
I'd be careful not to send the water directly into the neighbors' properties. That would get you into trouble, for sure. I'm just learning this stuff, too, so I'm no expert. My feeling is that the emitter would be appropriate if you were looking to redirect water into a storm drain or an edge of your yard where it wouldn't adversely impact neighbors. If it were me I think I'd just run solid pipe for a short section and then switch to perf pipe. And I'd keep it below the freeze line. If I really wanted to go the extra mile I'd install dry wells as the final destination. In fact, I'm about to make this very decision myself in a few days...
Old 05-24-2010, 11:55 AM   #15
I don't think that underground perforated pipes, even close to the surface, are going to do a good job of watering the lawn unless there are enough of them to cover the lawn less than 18 inches apart.
French Drain Help sloojoe Plumbing 10 05-05-2010 08:14 PM
French Drain Suggestions doublejz Landscaping & Lawn Care 10 04-29-2010 03:19 PM
French Drain Flagstone Path stevep7089 Landscaping & Lawn Care 1 05-24-2009 10:32 PM
creating a french drain ks2 Building & Construction 2 03-07-2009 12:15 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
