Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 07-24-2012, 01:48 PM   #1
Brown/damaged patch in lawn - grubs?
I've been concerned about some brown dry patches of grass in my lawn. I had assumed it was just not getting enough water, but yesterday when I was pulling some weeds I found the extent of the damage.
Basically the whole area just rolls up like a mat, leaving just bare soil. I saw plenty of bugs in there (mostly ants), but I didn't see any of those white grubs. I saw some bugs that looked like worms coiled up in a circle (not a great description). Is this grub damage? Looks similar to what I've seen when Googling it. Here are some pictures of the brown patch, and how it looks when I pull the grass back.
thinksincode is offline   Reply With Quote
Old 07-24-2012, 01:58 PM   #2
Have you seen any Japanese beetles flying around your yard? At this time of year they should be in their adult stage, so you won't see grubs in the ground. You might be seeing grub damage from earlier in the summer before the adults emerged. The grass may have survived the grubs but died in the heat because of the root damage.
You'll want to spread some milky spore before the next generation grubs start munching on the roots again (usually in late summer and fall). That is also when you should check again to see if grubs are present. The grubs will ingest the spores which will kill them, and the spores grow in their bodies and will continue to keep the grubs under control.
You can overseed in the fall, hopefully the grubs won't do too much more damage before the milky spore hits them.
Thunder Chicken is offline   Reply With Quote
Old 07-24-2012, 02:04 PM   #3
To answer your question, we have had quite a few beetles eating our flowers, but I don't think they're Japanese beetles - aren't Japanese beetles the ones with the metallic green color? The beetles I've seen look like them but are all brown. Here's the only picture I could find of one that my wife snapped.
Old 07-24-2012, 02:24 PM   #4
I forget the ID of that particular beetle (I don't think it is a Japanese beetle) but it is about the same thing. It has a grub stage that eats your grass roots. Milky spore will work against them as well.
Old 07-24-2012, 03:44 PM   #5
I did a little digging around and it looks like these are Oriental beetles: http://bugguide.net/node/view/23058
Old 07-24-2012, 04:50 PM   #6
So my other question is, how do I repair it? Just rake up the damaged area and put down some seed?
Old 07-27-2012, 12:57 PM   #7
Yes, that is pretty much all you can do. Some of those patches may not be dead, just dormant because of their shallow damaged roots. Hopefully the milky spore will take before they do further damage this fall. The grubs need to be feeding to intake milky spore. Once the lawn is innoculated with the spore it should last for a few years.
This fall I'd overseed a bit heavier than the instructions indicate expecting some loss to the last grubs, then I'd be ready to overseed again in the spring after you know what made it through the winter. After that you should be in good shape.
Tags
grass, grubs, insects, lawn
Sudden completely dry patch on my lawn?!?! Telfair Landscaping & Lawn Care 7 07-03-2012 02:49 PM
Grubs left patchy bare spots in my lawn E Collins Landscaping & Lawn Care 9 09-15-2010 06:20 PM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 09:14 PM
are the geese destroying my lawn? windowguy Landscaping & Lawn Care 17 04-16-2009 09:38 AM
Lawn problem - Grubs stevenblick Landscaping & Lawn Care 5 04-24-2007 03:17 PM
