Briggs Stratton Wont Start - 12hp Model: 498027 - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-14-2010, 06:53 PM   #1
Briggs Stratton wont start - 12hp model: 498027
Briggs Stratton model: 282707
Before putting the mower in the garage after mowing the yard, I shut it off for approx 10 min while using the leaf blower. When I tried to start, it never cranked but had been running fine when I cut the front and back. I even stopped and started it several times while I had to get off the mower and move stuff around. Checking the normal things, it still wouldn't start:
battery - ok
Gas - clean and flowing
Oil - full, clean, changed two weeks ago
Air filter - clean
Gas filter - clean, flowing
Carb - clean, parts moving freely
Spark - cleaned, the ensured it was sparking
Electrical connections - checked out ok
Flywheel/coil - removed dirt and very light rust
Pushed it into the garage and let it sit for a few hours, then tried again with the air filter off it backfires with the choke engaged through the air intake and muffler. It is getting gas, but never sounds like it is actually trying to run.
Any suggestions?
inetquestion is offline   Reply With Quote
Old 04-15-2010, 03:34 PM   #2
fixed it!
Took the head off to find the upper valve seat had come out. Tapped it back in with a punch and also around the rim to tighten the fit. Cranked on the first try and runs perfect. Hoping it doesn't happen again...
Old 04-16-2010, 06:57 PM   #3
Don't know it all, yet!
Now that's some DIY!
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
briggs engine 498027
5500w Briggs and Stratton Generator. RenoDon Electrical 18 05-05-2009 12:37 PM
Briggs and Stratton generator part Jeremy Hillary Boob, PhD Electrical 3 01-10-2009 10:36 AM
5+ Year old Briggs & Stratton Won't Start Chris_In_FL Landscaping & Lawn Care 1 08-28-2008 07:41 PM
Briggs and Stratton Murray lawn mower issues golfer2b Landscaping & Lawn Care 3 08-01-2008 09:42 PM
Briggs & Stratton recall Big Bill Safety 2 09-28-2007 04:35 AM
