Briggs And Stratton Engine - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 12-23-2011, 10:23 PM   #1
Rewards Points: 254
Briggs and Stratton Engine
I have a Yard Machine wood chipper with a Briggs and Stratton 4 cycle engine on it. Model 24A-462G129. Was mulching leaves with it today, it was running fine and all of a sudden it just died. I figured it was out of gas. It sounded like someone had moved the throttle to off, it throttled down and shut off....... I get the gas can and find more than a half was still in the tank. Odd.....I topped it off but it will not start back up.
Here is what I checked: It has spark, it has gas flow, clean carb ( was just replaced- I checked anyway, its clean). Tried putting gas directly in spark plug hole- it will not fire. Engine turns over freely. Oil is full and still clean. Im stumped!!!!
pwgsx is offline   Reply With Quote
Old 12-24-2011, 12:01 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
But do you have compression? Stick your finger in the sparkplug hole and give her a pull.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-24-2011, 10:03 AM   #3
Rewards Points: 254
yes it will suck my finger on the hole.
Old 12-24-2011, 10:41 AM   #4
Rewards Points: 79
Air filter?
Dwillems is offline   Reply With Quote
Old 12-24-2011, 10:57 AM   #5
Rewards Points: 254
clean, just replaced
Old 12-24-2011, 11:07 AM   #6
Missouri Bound's Avatar
Compression, fuel and spark.....that's the big three. Timing is an issue. Have you checked the shear pin on the flywheel?
Old 12-27-2011, 09:39 AM   #7
Rewards Points: 254
Got a compression tester, only had 20 psi
Old 12-27-2011, 11:53 AM   #8
Rewards Points: 48
So now, as Missouri Bound suggested, pull the flywheel; most likely it's a key, but regardless, it is probably bad, and that's probably not uncommon for that application. Try to pick up an OEM one, because it's cheaper to replace a key than a crankshaft and/or block.
Old 12-27-2011, 02:20 PM   #9
Rewards Points: 254
so what usually happens? The flywheel key snaps?Im confused, When I pull on the cord, its turning the motor over and it has spark so the flywheel has to be attached ???
Old 12-27-2011, 02:45 PM   #10
Rewards Points: 48
Sometimes the key will break completely, and sometimes it will stay intact but bend enough to cause the timing to get off enough to not run. Either way, it's held onto the taper with a nut, so will still turn, but be out of time. I obviously can't say for certain that is the problem, but, based on what you have found so far, that is what I would check next. Not too bad of a job; remove something like 4 or five bolts that hold the cover in place, slide the cover off, loosen the nut to the point that it is flush with the end of the crankshaft, rap it firmly but not forcefully a couple of times with a block of wood between it and a hammer, pull the flywheel off, and inspect the key.
Old 12-27-2011, 03:56 PM   #11
Rewards Points: 254
sounds good, ill look into it this week
Old 12-27-2011, 11:26 PM   #12
Disabled wood vet
titanoman's Avatar
Whose to say 20psi ain't enough in a b&s (?). Try different gas?
The Following User Says Thank You to titanoman For This Useful Post:
DexterII (12-28-2011)
Old 12-28-2011, 05:27 AM   #13
Rewards Points: 48
OP, I forgot to mention this, but yes, titanoman is 100% correct; 20 psi on this engine is not necessarily indicative of a problem. But, it's probably a bit low, so given what you have checked so far, it seems reasonable to me to check it out, since, again, it's not much work to get there.
Old 12-28-2011, 08:36 AM   #14
Rewards Points: 472
I didn't read the other post's. It may have a low oil senser on the motor. If the oil is low it will not run . Check and see it will have one wire going to it . I don't know where it is located but i guess look and see if their is a wire going to the motor down where the oil sump is . If the oil is ok remove it and see if it run's. If so you can do 2 thing's replace or just run motor if oil is ok. This is just to keep motor from seizing up if oil ran out .
del schisler is offline   Reply With Quote
Old 12-28-2011, 12:34 PM   #15
He said he had spark. When the low oil sensor is activated there is no spark.
The Following User Says Thank You to Missouri Bound For This Useful Post:
del schisler (12-28-2011)
Briggs & Stratton repair HAllen Automotive Repairs 1 03-15-2012 09:11 PM
Briggs & Stratton Fuel Problem/ No start rod46 Landscaping & Lawn Care 4 05-09-2010 03:53 AM
Briggs and Stratton generator part Jeremy Hillary Boob, PhD Electrical 3 01-10-2009 11:36 AM
5+ Year old Briggs & Stratton Won't Start Chris_In_FL Landscaping & Lawn Care 1 08-28-2008 08:41 PM
Briggs and Stratton Murray lawn mower issues golfer2b Landscaping & Lawn Care 3 08-01-2008 10:42 PM
