Briggs And Straton Engine Trouble - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-11-2008, 04:07 PM   #1
briggs and straton engine trouble
i have an old generator with a briggs and stranton 5 hp engine on it. its old but runs great. this morning i went to start it and on choke it runs great but when i shut the choke off it kills the engine. any body have any ideas where to start to fix this. thanks spurrowl
spurrowl is offline   Reply With Quote
Old 11-11-2008, 08:50 PM   #2
I'd start by checking your fuel line and with a new fuel filter.
white29 is offline   Reply With Quote
Old 11-16-2008, 08:41 AM   #3
WFO
If the carb has a float bowl, remove it and see if your pilot jet is clogged. If it is, don't use a drill bit or anything else to clean it that would enlarge the hole. Instead, cut one bristle off a wire brush; they work great to get the gunk out and is small enough to fit the tiny orifice.
WFO is offline   Reply With Quote
Old 11-23-2008, 08:25 AM   #4
freshman
Pipeline's Avatar
I have the same motor for lawn mower
the startup went ok but 2-3 secs later it dies
I started pusing gas primer[upon advice] during [just right after start up] and bingo motor stayed alive and no longer needed to do more pusing after motor starts again
there seems to be an air leak for pushing the fuel into the motor
low pressure
So deffo fuel related with your problem, spurrowl
Pipeline is offline   Reply With Quote
Old 07-02-2013, 01:25 AM   #5
I have the same engine for my rototiller. The spark when I turn over the engine is very weak. I was wondering if the ignition module is faulty? I've check the air gap and it is correct. The contacts are clean.
sluggermike is offline   Reply With Quote
Old 07-02-2013, 05:19 AM   #6
Rewards Points: 13,712
The carburetor is dirty, remove it take it apart, clean it with carburetor cleaner and rebuild it.
Main reason, using ethanol fuel without adding an additive to counteract the effects of it or using non ethanol fuel.
Sluggermike it would be best if you want back and added your own post not add onto someone else's.
Old 07-02-2013, 04:10 PM   #7
Ethanol will damage plastic but it is much much cleaner then regular gas. It has been known to loosen old deposits that clog engines but it has nothing to do with the ethanol being bad in anyway.
Tatertot is offline   Reply With Quote
Old 07-02-2013, 05:21 PM   #8
Rewards Points: 91
Holy thread necro!
NegativeTen is offline   Reply With Quote
Old 07-02-2013, 06:15 PM   #9
Doh, yeah no kidding. All threads should lock after a period of no posts.
Old 07-03-2013, 08:17 PM   #10
biggles's Avatar
opening in the bowl nut might be blocked as suggested I use a small needle from sewing kit should be able to blow thru it when clear...anybody with a float bowl on any type engine has this item and needs to be maintained and bowl cleaned out in the start up seasons
Old 07-04-2013, 06:58 AM   #11
DIY staff
Rewards Points: 7,174
Handiest thin wire in the house? A twister tie from a loaf of bread---
This thread may be old,but the info is not----
