Brick Pavers - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-08-2012, 11:42 AM   #1
brick pavers
i installed a patio using 10"by 10" by3" thick bricks. i use a base of crushed limestone. the area is 1000 square feet. it is basically flat but i have somedges sticking up as much as a quarter inch. i was thinking of running a plate tamper over it. will it help.
brian pennino is offline   Reply With Quote
Old 07-08-2012, 12:43 PM   #2
Remodeling Contractor
yes. But why? The sub-base must be flat and compacted first
Old 07-08-2012, 02:54 PM   #3
Civil Engineer
Rewards Points: 4,682
You say you have some edges sticking up 1/4 inch. Do you mean the edges of the brick? If you run a plate tamper over brick that is high, you run the risk of damaging the brick. The crushed stone is a great base, but you usually want to put down an inch or two of masons sand on top of the stone to bed the brick in, much easier to get a flat surface with sand than crushed stone.
Daniel Holzman is online now   Reply With Quote
Cutting Cement Pavers and Brick Thadius856 Landscaping & Lawn Care 16 09-02-2011 10:59 AM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
Damaged brick pavers turbomangt Landscaping & Lawn Care 1 12-02-2009 12:41 AM
Mortar or thin set for brick pavers bdawson General DIY Discussions 0 04-27-2008 01:44 PM
Brick pavers on driveway ???? sflamedic General DIY Discussions 2 04-21-2008 11:12 AM
