Brick Paver Question - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-27-2013, 12:33 PM   #1
Brick paver question
Hi,
I have a paver patio and the person who did it for some reason placed the first row of pavers on a row of retaining walls. They kept coming loose so I took them off and applied mortar to the top of the retaining blocks and placed the pavers on top. Its been about 2 hrs and the mortar is not tried yet so the pavers are not adhering. Is this normal?
markharmon is offline   Reply With Quote
Old 04-27-2013, 03:40 PM   #2
Rewards Points: 91
It will depend heavily on the type/mix of mortar you used, as well as environmental factors (weather, humidity, etc). If you didn't specifically get a quick-drying mortar, or if you mixed it too wet, it could take days to set up, and even longer to fully cure.
NegativeTen is offline   Reply With Quote
Brick Jack Arch - options for cutting brick PAbuilder Concrete, Stone & Masonry 4 01-30-2013 07:00 PM
Brick paver walkway Twomeymj Concrete, Stone & Masonry 0 06-08-2012 12:10 PM
concrete brick paver is good for patio? diy001 Landscaping & Lawn Care 2 05-21-2012 08:29 PM
red wall brick as ground paver in the yard? hohadcr Landscaping & Lawn Care 6 08-09-2011 08:02 AM
Started Exposed Brick Wall, Studs within brick, should I stop? perry167 Building & Construction 4 01-05-2011 09:41 AM
