Brick Paver Help Needed - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-15-2010, 08:56 AM   #1
Brick paver help needed
I'm knee deep into insalling a clay paver walkway and having difficulty getting my sub base level. The walk is 22' x 4' and slopes about 4'' lengthwize. I've dug to 12", compacted the subsoil and have so far added 2 - 3" layers of crushed base compacting in between. I'm doing fine keeping it level side to side, but am getting lots of high/low areas lengthwise. All the online info states a "level subbase" but don't tell you how to achive this. I desperatly need to correct this in my last layer of base. Any help would be GREATLY APPRECIATED!
jkon51 is offline   Reply With Quote
Old 04-15-2010, 09:23 AM   #2
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Hammer stakes into each corner and run a string between them. Use the string for reference?
CoconutPete is offline   Reply With Quote
Old 04-15-2010, 05:40 PM   #3
GardenConcepts's Avatar
Rewards Points: 150
I use screed pipes to do what you are trying to do. If you buy 4 pcs. of 1" heavy duty galvanized electrical conduit, you'll have screed pipes. Get your crushed stone close to finish height (up and down waves in the surface is ok, but try to get it close to finish height minus 1".). Then set the top of the pipes where you want the top of the finished gravel. Get a straight piece of 2 x 4 and scrape/screed the gravel perpendicular to the pipes. When you are finished, remove the pipes and carefully fill in the grooves left behind and compact.
GardenConcepts is offline   Reply With Quote
The Following User Says Thank You to GardenConcepts For This Useful Post:
whataboutj (04-19-2010)
Old 04-16-2010, 10:57 AM   #4
Thanks! I have been sceeding the base material but without the rails, I don't know why it didn't occur to me to do it the same way the setting sand is done. Thanks again.
Old 04-16-2010, 04:12 PM   #5
pavers
Great advice on the pipes! Will use that for other leveling projects.
Allison1888 is offline   Reply With Quote
Old 04-16-2010, 05:09 PM   #6
Rewards Points: 582
http://www.pavingexpert.com/
This site may give you some usefull info.
stuart45 is offline   Reply With Quote
The Following User Says Thank You to stuart45 For This Useful Post:
Brick Paver Driveway Sealing gjbarlow Landscaping & Lawn Care 5 04-10-2011 08:02 AM
brick paver patio fishin dude Landscaping & Lawn Care 7 03-03-2010 11:10 PM
Paint the brick or not? Walkway? Advice NEEDED! Carssson General DIY Discussions 24 09-08-2009 05:52 PM
Redwood Deck Over existing brick paver patio areacode516 General DIY Discussions 3 04-12-2009 09:09 PM
Sealing historic brick tenzo General DIY Discussions 2 11-22-2008 03:04 PM
