Brick Over Existing Cement Patio - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-27-2010, 09:47 AM   #1
brick over existing cement patio
i am going to install a brick (4x8x2 size brick) patio over an existing cement patio. the cement patio is small, approx 8x8 and it bordered on all sides by wood timbers supporting a fence. the 2" thick bricks are just slightly higher than the wood timbers and dont present a problem with the door opening. my question is, can i simply lay the bricks on the concrete and fill the spaces with masons sand? or do i need a base of sand under them? i think the patio has some drainage holes built into it.
cjaybiker is offline   Reply With Quote
Changing existing brick mortar color bladesj General DIY Discussions 5 07-23-2010 01:41 PM
Concrete Patio with brick ribbons vactek Building & Construction 4 04-11-2010 10:10 PM
Adding stone to existing brick chimney TVC15 Building & Construction 5 08-13-2008 05:19 PM
Attaching lean to patio roof to existing roof Jackhammer Roofing/Siding 3 05-27-2008 07:13 PM
Addition around existing brick chimney Adenmoor Building & Construction 2 11-20-2004 10:37 PM
