Bradford Pear Root Problem - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-07-2012, 06:26 PM   #1
Rewards Points: 29
We planted a ~8' Bradford Pear tree in the front yard of our new house about eight years ago. For the past couple years, we have had a large number of "root shoots" (don't know what else to call 'em...) popping up all around the tree out to a distance of about 10'. Last year, we went ballistic with a shovel and an axe and whacked away all the roots within a couple feet of the surface. Some of them were quite thick and caused me to use all thirteen sailor words.
The tree is now 20-odd feet tall, healthy as hell, and growing like I wish my grass would.
Question: How does one keep the root-shoots from popping up all around the tree? My wife is very annoyed, and when Momma ain't happy...
Thanks...
PS: I was thinking of a crane, a good chain, and a large hole in the ground into which I could plant something else. But that seems a bit extreme...
slickwilliam is offline   Reply With Quote
Old 06-08-2012, 02:56 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 396
[quote=slickwilliam;938606]We planted a ~8' Bradford Pear tree in the front yard of our new house about eight years ago. For the past couple years, we have had a large number of "root shoots" (don't know what else to call 'em...) popping up all around the tree out to a distance of about 10'. Last year, we went ballistic with a shovel and an axe and whacked away all the roots within a couple feet of the surface. Some of them were quite thick and caused me to use all thirteen sailor words.
Thanks...
PS: I was thinking of a crane, a good chain, and a large hole in the ground into which I could plant something else. But that seems a bit extreme...[/quote]
might be the only option
Old 06-08-2012, 05:40 AM   #3
biggles's Avatar
if you attacked it as described and you didn't shock it as in dying..draw a 10' diameter circle around the tree 5' out from the truck center around.get a sawzall recip saw with a long blade and cut downward anything outside the circle around.ring the tree with cobble stones and dump a mulch layer 2"-3" deep to define it
Old 06-08-2012, 06:15 PM   #4
Craftster
ghostlyvision's Avatar
Rewards Points: 95
Between the root shoots and the sprouts that come up from its seeds, you'll probably always be fighting a losing battle, and the bigger the tree gets, the less grass you'll have in your yard. And it has a weak branching system and strong winds will knock branches off, hopefully not on your house or car. You'd be better off getting it out of your yard before it gets any bigger and more expensive to do so.
ghostlyvision is offline   Reply With Quote
Old 06-09-2012, 04:11 AM   #5
chrisn's Avatar
Rewards Points: 396
Having been in the tree industry for many years,I truly hate to remove any tree without very good reason. In this case I agree with the above. Bradford pears are probably one of the most widely over planted species out there and the bigger they get the more chance of them splitting and falling, unless they are properly pruned and cabled.
Advice for Water Problem in Garage jschweg Building & Construction 15 04-17-2012 01:00 PM
Problem with toilet (vent problem?) branch155 Plumbing 24 03-09-2012 09:37 AM
Bradford White water heater adpanko Plumbing 0 02-10-2010 03:33 PM
Help with serious flooding problem MNUZZI Landscaping & Lawn Care 12 10-03-2008 02:46 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
