Boxwood Is Dying... Cause? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-13-2010, 11:25 PM   #1
Rewards Points: 77
Boxwood is dying... cause?
One of my boxwoods has turned a mostly orangish color. There is another boxwood about 10 ft down the hedge that is showing the early signs of doing the same thing. It is dark out right now, but I took a picture of on of the clippings. Hopefully someone can recognize what the symptoms are or what might have caused this.
It is possible that the plants got slightly 'misted' when using some weed-b-gon max (the can that is attached to a hose) but would have been minimal. Boxwoods on either side have not been effected but would have probably also been subjected to the slight mist.
I have also read about a fungus that seems to be common in boxwoods but I havnt really seen any black spots that would indicate fungus. The only other thing is possibly the root rot. We had flooding from about 2 days of straight rain totalling 9.8". Neither my yard or landscaping were holding water so I'm a bit skeptical of this being the problem. I'm just a bit clueless right now. I'll try to get a wide shot of the boxwood with the adjacent boxwoods in view.
Also is this going to be save-able or do I need to dig it out and plant a new one? Thanks.
eemichael83 is offline   Reply With Quote
Old 05-14-2010, 04:22 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
http://www.pubs.ext.vt.edu/450/450-614/450-614.html
good luck
Old 05-14-2010, 06:58 PM   #3
Don't know it all, yet!
A couple of questions on the rainy spell. When you say the yard did not hold water, do you mean there was no water standing or how did you come to that conclusion? I have a specific reason for asking. Also, when did this problem occur relative to the rain?
I am leaning toward the accidental overspray of the herbicide. I haven't seen it with the green edges and brown centers but that could be due to several factors.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
25 year old GE Heat Pump is dying. Which new one to buy? barnesch HVAC 3 12-18-2009 03:37 PM
Is my lemon tree is dying? Rookie owner Landscaping & Lawn Care 3 07-07-2008 10:24 AM
Large areas of grass dying Shpigford Landscaping & Lawn Care 6 07-05-2008 04:24 PM
American Boxwood shrub is dying CalebsMom Landscaping & Lawn Care 3 05-19-2008 09:22 PM
Dying carpets nannyk Flooring 2 10-14-2006 01:27 AM
