Bought A House, Backyard Has Slight Slope Towards The House - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-24-2013, 08:34 AM   #16
r0ckstarr's Avatar
Rewards Points: 1,980
However, you do not want a "level" yard. You want it to slope away from your home. Make sure that you have at least a quarter of an inch drop in elevation per foot of linear travel away from the house. For example, in ten feet of distance (10 X 1/4 inch = 10 quarters of an inch, or, 2 1/2 inches drop) you will need the earth to slope down and away about 2 1/2 inches. And, therefore, if you go twenty feet away you will need 5 inches of positive drainage slope away from your structure. From there you may flatten out to more level ground but always always always maintain positive drainage away from your home.
what you would do is get two stakes and place them at the two ends of the area you want to make level. String a line tautly between the two stakes and hang your level on it in the middle of the string, then adjust the height of the string until the level indicates the string is, well, level.
After you are certain the string is level and straight--not sagging, measure from the area under the string that is longest and remove the dirt beneath the string until every area matches that measurement. You could also add dirt to the low areas instead of remove dirt from the high areas or do a combination of the two--what is important is that the area beneath the string be the same measurement along the total string length.
http://wiki.answers.com/Q/How_do_you...a_string_level
r0ckstarr is online now   Reply With Quote
The Following User Says Thank You to r0ckstarr For This Useful Post:
markx83 (04-24-2013)
Advice on slope next to house needed SingleGuy Landscaping & Lawn Care 24 04-12-2012 11:59 AM
Just bought our "Forever Home" fixer-upper Geneticswhiz Introductions 5 09-22-2011 11:06 AM
How to make slope grade away from house? ans630 Landscaping & Lawn Care 7 04-06-2007 10:58 PM
Slight slope to floor sweetsue777 General DIY Discussions 3 01-10-2007 01:58 PM
backing out of the house i bought this old house Building & Construction 9 11-19-2005 01:56 PM
