Bolens Mower Starts, Then Dies - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-05-2010, 01:12 PM   #1
Rewards Points: 590
Bolens mower starts, then dies
The engine is a B&S 4-stroke with no throttle. I bought it last year late in the summer and it has been used for only a few hours. If I prime the engine, then pull, the engine will run for a moment and die. I can repeat this cycle every time. If I have someone push the priming bulb right after it starts, it will run a moment longer before dying. That seems to tell me it's not getting fuel. I attribute this to me leaving old gas without stabilizer in it over the winter. I am going to try cleaning the carb with carb cleaner and checking the spark plug, but does anyone have any other suggestions?
operagost is offline   Reply With Quote
Old 04-05-2010, 01:34 PM   #2
the Musigician
DangerMouse's Avatar
Fouled/clogged fuel filter and/or line I would guess.
Check air filter as well.
DM
Old 04-05-2010, 01:47 PM   #3
Rewards Points: 590
I cleaned the foam air filter, as it was covered with sludge in the openings. I did find out that you're actually supposed to have a little (clean) oil in these to help catch the dirt, so I'll be putting a little 30 weight back in.
This is a push mower; if there's a fuel filter, I don't know where it is. Neither the Bolens nor the B&S manuals that came with the mower mention it.
Old 04-05-2010, 11:56 PM   #4
Rewards Points: 590
A little Gumout sprayed into the carb did the trick.
Toro Recycler mower w/ Tecumseh 6.5 engine - starts and immediately dies Pickngrin Landscaping & Lawn Care 40 07-14-2012 06:43 PM
Lawn Mower Not Starting - Any ideas? topgun129 General DIY Discussions 1 07-16-2009 06:52 PM
Solar Charged Brushless Lawn Mower Educator Electrical 2 04-20-2008 12:43 PM
What do you guys think of my new mower? :) (pics!) joeyboy Landscaping & Lawn Care 20 09-23-2007 08:59 AM
Engine Slowly Loses Power and Dies While Driving slickshift Automotive Repairs 16 01-15-2007 11:34 AM
