Blown Out Backflush Valve - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-11-2013, 08:32 PM   #1
JPM
Bill Traver
Rewards Points: 101
I am new to sprinkler systems. I blew out the lines last fall but forgot to turn off the water valve going outside ... consequently, my TORO backflush valve started to leak. I am wondering if I need to replace the whole thing or just the parts inside (spring and some plastic pieces)? When I turn the water on and open both valves on the unit, water pushes out the top.
Thanks for your help.
JPM is offline   Reply With Quote
Old 07-11-2013, 09:08 PM   #2
Rewards Points: 44
You can replace just the parts. You may find the parts cost more than the valve. However replacing the whole valve could be a project depending upon how the current one is installed.
Dan
djlandkpl is offline   Reply With Quote
Backwater Valve Installation CCCron Plumbing 2 10-24-2014 09:52 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Cant get the valve off (with picture) clof2001 Plumbing 3 05-10-2010 03:04 AM
Need Replacement Gas Shut Off Value with Side Port for Pilot Light - Photos Available BobN HVAC 12 03-10-2009 12:02 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
