Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 03-09-2011, 12:31 PM   #1
Black or white yard drainage pipes
Hi All,
Apologies if this has been covered before, couldn't find it.
I'm having the French drains replaced in my yard because whoever did it before did a cr4ppy job, and since we are having the lawn re-seeded it is the perfect time. Would it be worth the additional outlay of getting the white rigid drain pipe laid so it can be snaked if it gets clogged in the future?
Cheers
Chris
spiragui is offline   Reply With Quote
Old 03-09-2011, 03:15 PM   #2
47_47's Avatar
Personal preference is to use a smooth inner walled white pipe.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is offline   Reply With Quote
Old 03-09-2011, 03:44 PM   #3
concretemasonry's Avatar
no question.
Rigid pipe can be laid to a desired grade and does not belly. The smooth surface will run cleaner and faster and not accumulate sediment unless it is installed improperly. You can also transition from perforated to solid and back depending on your needs. You may want solid to carry water under a sidewalk without satuarting the soil in that area.
You can get fittings to allow snaking or flushing at any point you chose to have an access.
Dick
concretemasonry is offline   Reply With Quote
Tags
french drain, pipe type, yard drainage
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
Help with four way switch jwetsit Electrical 3 05-04-2010 07:05 AM
Black & White kitchen questions TraGregZ Remodeling 4 01-06-2010 12:34 PM
Black and white romex for 220v circuit? NateHanson Electrical 2 05-02-2007 05:43 PM
white sedement in pipes handifoot Plumbing 5 02-21-2006 09:15 PM
