Big Puddle Problem - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-27-2014, 04:19 PM   #1
Rewards Points: 16
Big Puddle Problem
I think I know the answer but want a couple second opinions before I start digging. Just put in a new driveway that is wider than the old one. The driveway slopes toward the hill and the hill (although small) slopes towards the driveway and you guessed it - puddle!!!! See pic. Soil has a lot of clay content. It takes about a day to drain away and leaves a little brown dirt stain on my new concrete. My thought was this is a classic situation where a little drain tile buried next to the driveway and run out to the gutter drain which heads to the street would drain the area. Do you think this would be enough or should I just go ahead and install a little drain in the edge of the concrete and connect it in to the gutter drain. Hate to cut up the concrete if I don't have to.
Speckert is offline   Reply With Quote
Old 03-27-2014, 06:37 PM   #2
Rewards Points: 284
I try to avoid pipes when I can. I would remove the dirt. At least 2' wide and at least an inch below below driveway.
JustinK is offline   Reply With Quote
Old 03-27-2014, 08:43 PM   #3
Rewards Points: 16
I will give that a try. A lot less digging involved.
Old 03-28-2014, 05:36 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,730
Ayuh,.... Water, Flows Downhill,.... Lower the dirt,....
Bondo is online now   Reply With Quote
Old 03-31-2014, 02:22 PM   #5
As sarcastic as this sounds, it is the truth
Altered Grounds Landscaping
mbender2004 is offline   Reply With Quote
Old 03-31-2014, 02:38 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 2,124
French Drain....
Dig down about 12"....and about 12" wide....lay down a layer of gravel about 8" deep...cover with dirt. The gravel should remove most of the water.
And while your at it...lower the level of the dirt.....and maybe plant some grass?
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
