BG55 Stihl Leaf Blower Limping Along - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-21-2009, 02:41 PM   #1
BG55 Stihl Leaf blower limping along
Worked without any maintenance or repairs since 2002.
Now it won't go full speed.
Replaced the fuel and air filters and the plug.
The parts guy says he hardly ever sells magnetos for this machine.
Adjusting the high speed mixture screw doesn't help so I returned it to factory setting.
It runs at half speed and then seems to pick up some speed but if the throttle is squeezed to full, it dies. Then I release the throttle, it idles OK, and then the whole sequence is repeated.
The throttle cable moves the throttle plate through the full range.
Besides getting more fresh gas and making sure the fuel pickup is tucked down in the tank where it should be, anybody have any ideas what could be wrong with this machine?
Old 01-11-2010, 05:26 PM   #2
I don't know if you ever figured out what is wrong or not, but check your exhaust for cabon or oil build-up. If it's a 2002 that's quite a few years of run time. I had an old weedeater that exhibited the same symptoms some years back and I found the exhaust system gummed up with unburned two stroke oil. I took off the muffler, and cleaned it with solvent. I then torched it with a propane torch and burned all of that crap out ( it took a while). It ran good afterwards.
scarpen01 is offline   Reply With Quote
Old 01-11-2010, 05:41 PM   #3
It's the next thing in my inbox.
A hospital stay for my wife intervened in this project, and a lot of other projects, during which time I found I could stay awake for 34 hours.
When they finally figured out what was wrong, they operated - on New Year's Eve, my birthday.
She's on the mend. It was the best present, ever.
Thanks for your help, all.
Old 01-14-2010, 11:00 AM   #4
Glad to hear she's better and Happy Birthday! Something I thought about after my first reply to your question on your leaf blower, a simple check on the exhaust is there sould be a deflecter right at the outlet with a couple of screws. Remove the screws and there should be a screen located just inside (spark arrester). This is usally the main place for unburned two stroke oil build-up. You can usually clean this for quick results, but it will generally get back on there in a hurry if you have a lot of build-up in the rest of the muffler. That's when a good cleaning of the whole muffler is in order. Hopefully it will get it going for you.
Old 01-14-2010, 09:50 PM   #5
firehawkmph's Avatar
Rewards Points: 1,920
Yoyze,
If it doesn't turn out to be the exhaust, two other things come to mind. My buddy and I both have the same blower as you. The rubber fuel line developed a hole in it after a good number of years. It is a special piece you have to replace with the stihl part.
If that isn't it, about the only other thing that acts up are the pumper style carbs on all the small two strokes. They have a few thin rubber diaphagms in them. If one cracks, it won't pump enough fuel which would present itself like yours. Let us know what you find.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-14-2010, 10:01 PM   #6
Thanks, folks. I should start disassembly pretty soon.
Heat comes on but blower never does aczer HVAC 12 02-13-2011 06:57 AM
Furnace will not stay on allenzachary HVAC 32 09-21-2010 08:30 PM
Electric Leaf Blower sweaty Electrical 1 10-27-2009 10:11 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 04:00 PM
