Best Way To Secure An Arbor - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-02-2010, 02:46 PM   #1
Rewards Points: 117
Best way to secure an arbor
The grape arbor I'm getting is probably exactly this one: http://www.yardarbors.com/wooden-yar...en-arbors.html , though I'm getting it from a local garden center for $400.
I plan on putting it on the edge of the mow line because the trees right on that line have a bazillion grapes vines hanging from them.
Do I need to use 4 concrete footings? Or can I get away with some semi-buried 4x4 PT posts in some config?
tgm1024 is offline   Reply With Quote
Old 08-05-2010, 09:01 AM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Are the posts on this 4x4? I would think that concrete footings are serious overkill. They make anchors for 4x4's that are commonly used for mailboxes. You just hammer into ground, insert 4x4 and lag bolt it.
there are screw in models as well
http://www.amazon.com/Mayne-580D-BK-...1016705&sr=1-1
http://www.homedepot.com/Tools-Hardw...atalogId=10053
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
The Following User Says Thank You to Mr Chips For This Useful Post:
tgm1024 (08-08-2010)
Old 08-05-2010, 01:23 PM   #3
Rewards Points: 117
No, I believe they are more like cedar 2x3. Surprisingly sturdy given that. But those post anchors are expensive and overkill when I add 4 of them to the mix. Diagonally opposing 2 of them might do the trick, but I'm beginning to wonder if I'm not just better off sinking my own 4x4 PT's as "feet". Possibly transverse.
Old 08-05-2010, 01:47 PM   #4
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
if you want to do on the cheap, here's a quick and dirty method to keep it from falling over:
Get yourself 4 pieces of rebar,3' to 4' long. Get some Rustoleum or other outdoor paint that is a brown color, paint 2' on one end of each rod. Pound the unpainted end into the ground, leaving 1' to 1-1/2 of the painted end sticking out. Use 2 galvanized pipe straps to attach the rods to each leg of the arbor. The straps don't have to be a tight fit. just put one down low, the idea is to keep it from tumbling over.
Job done in 10 minutes (after paint dries) for under $20
Old 08-05-2010, 04:17 PM   #5
Rewards Points: 117
.............................................not bad
Old 08-06-2010, 12:48 PM   #6
Rewards Points: 150
The re-bar is not a bad idea.......but if you want to expand on that method, do put a concrete footer so to speak under each leg of the arbor and sink a inch by inch angle iron from lowes into the wet concrete and lag screw using galvinized if possible. I'd come up out of the ground three feet with the angle steel. Do all this while concrete is still wet. The arbor is beautiful, but be careful on final setting ,make sure the legs are in a perfect x in inches and if you do set in concrete ,put a side brace out temporarily untill the crete gets hard. If the x isn't perfect, it'll look out of plumb.
bernieb is offline   Reply With Quote
The Following User Says Thank You to bernieb For This Useful Post:
Old 08-08-2010, 08:42 AM   #7
Rewards Points: 117
That's the problem. I'll agonize over it standing at 0.00000001 off of 90. Plus, I'll need something I can easily adjust over time to compensate for suttle warping of the structure which *always* happens no matter how much treatment is on it. The solution has to meet the following requirements:
  1. Doesn't lend itself to an OCD agonizing .
  2. Could be left alone as permanent should it go out of sight out of mind.
  3. Could be easily tweaked when the grade shifts, or the wood dries, or I agonize over it being out of line with the off-plumb playset, or or or...
LOL....
Old 08-08-2010, 11:07 AM   #8
Rewards Points: 150
I do appreciate your concern for being plumb on your arbor. A feature such as that can add 10 thousand dollars to the value of your property if done right, so don't squack about an extra 50 bucks in the final setting. I can tell your on the right track and good luck.
Old 08-09-2010, 05:22 AM   #9
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
T think the angle iron, wrapping around the corner is a great idea, but I am curious why you recommend coming up so high?
I would think that if you positioned the angle iron so that they all faced in (or out) you would only need about 6" coming up out of the concrete, maybe even less since you are getting the added support of the angle, all you really need is a single lag bolt in each leg and the arbour isn't going anywhere. what am i missing here?
Old 08-09-2010, 01:10 PM   #10
Rewards Points: 150
You are no doubt right Mr Chips with the height on the angle iron. I tend to think about kids running about. Anyway I think we got the o'l boy on the right track.
Old 08-09-2010, 07:40 PM   #11
Rewards Points: 117
I chuckled over this. I tend to over-engineer everything as well. Anything within 100 feet of water is stainless steel. Any "glue" is NASA grade epoxy. Glue guns give me the heebeejeebees.
Thanks all!
New Arbor Seal & Paint Tall007 Carpentry 0 03-08-2010 11:04 AM
How to make basement door more secure? doublesharp Building & Construction 11 11-27-2009 06:20 AM
odd sized table saw arbor Ricardo54 General DIY Discussions 1 10-16-2009 03:12 PM
How do I secure T-Moulding and thresholds vloh7 Flooring 6 01-30-2009 03:55 PM
Adding a snow supporting arbor snmhanson Building & Construction 2 12-15-2006 06:21 PM
