Best Way To Repair Concrete Retaining Walls? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-24-2009, 03:27 AM   #1
Rewards Points: 200
Exclamation
Best way to repair concrete retaining walls?
Dear all, first please see some photos:
http://yfrog.com/7gdsc0483largej
http://yfrog.com/05dsc0481wj
The concrete retaining wall in our backyard used to have a "cap", but because the wall is aging so the cap is falling apart and we recently just decide to take the cap out.
However, after we took the cap out, we noticed that the fence was built with steel and concrete, and the steel inside the concrete is really rusty. Some questions here:
1. What would be the best way to repair this retaining wall? Would simply putting concrete on the top edge work?
2. How could we make sure that the still is being protected and won't continue to rust? It seems that if the steel continue to rust, eventually the concrete wall will "bubble"... any thoughts or comments about this?
Thanks again for your help!
ohman is offline   Reply With Quote
Old 06-24-2009, 09:19 AM   #2
47_47's Avatar
Rewards Points: 44
Steel needs oxygen and water/moisture to rust. Remove either and it will stop oxidizing.
Really couldn't tell much from the photos to advise on how to secure a new top cap.
47_47 is offline   Reply With Quote
Old 06-25-2009, 12:45 PM   #3
Rewards Points: 200
Would it be a good idea to just put concrete on top of the wall and make it look like a ^ shape, would that work?
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
doing up a basment littleparr Building & Construction 7 04-08-2008 09:28 PM
Concrete Slab Repair sportnmud General DIY Discussions 1 10-10-2007 10:29 PM
Concrete walls on wooden joists stonehanger Building & Construction 3 11-24-2006 05:26 PM
