Best Way To Remove Old Rotted Stump - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-26-2011, 07:25 AM   #1
Best way to remove old rotted stump
We had a big ol mango tree in our back yard that was cut down maybe 5-7 years ago. The stump is still in the ground. Its fairly big at maybe 3 feet wide, maybe a little more. Its since died and rotted and is termite eaten. Whats the best way to remove this stump?
anonymoususer is offline   Reply With Quote
Old 03-26-2011, 07:39 AM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
backhoe
sawzall and a shovel
stump grinder
landscape feature.....
tcleve4911 is offline   Reply With Quote
Old 03-26-2011, 07:53 AM   #3
Rewards Points: 1,088
Gasoline and match.
handy man88 is offline   Reply With Quote
Old 03-26-2011, 08:13 AM   #4
Stay-at-home GC
Wasn't there a product out many years ago that would rot the stump from the inside?
Potassium permangenate or something? Seems like you drilled holes in the top of the stump, poured in these crystals and a few months later dug out the rotted pieces.
Don't remember for sure, just that it made for good bombs
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 03-26-2011, 09:36 AM   #5
Yeah, there is. You can find this stump remover from HD or Walmart....about $5-10/bottle.
The only problem is that it takes about 6 months for a dried stump to decompose after you apply it. You cannot use it on a freshly cut, green stump.
Some stump products cause a smoldering effect that eats the stump down to the root.
http://www.eburgess.com/detail.asp?pid=8460
Other stump products cause the stump to be porous whereby then they recommend you burn it.
http://www.google.com/products/catal...d=0CDoQ8wIwBA#
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Old 03-26-2011, 10:19 PM   #6
Rewards Points: 410
A pick axe works well I've found and gives a good upper body workout.
High Gear is offline   Reply With Quote
Old 03-26-2011, 10:53 PM   #7
Rewards Points: 1,016
Old 03-27-2011, 12:50 AM   #8
General Contractor
SeattleSurfaces's Avatar
Dynamite! Plus it is fun to watch and it freaks the neighbors out.
SeattleSurfaces is offline   Reply With Quote
Old 03-27-2011, 01:53 AM   #9
Let me get this straight... i apply the product then the stump self ignites?
I was actually thinking about getting a regular axe. I'll be an awesome upper body and abdominal workout.
Old 03-27-2011, 07:52 AM   #10
I think a chemical reaction causes a smoldering effect, but it's not on fire.
One product (Burgess) seems self contained. The other products eats away at the stump, but then requires the rest of the stump to be burned.
BTW, digging out a stump is no fun. Not only will you need an axe, but also a good shovel, a good back, and probably physical therapy afterwards.
Old 03-27-2011, 07:58 AM   #11
Stay-at-home GC
I wonder how that concrete cracking agent Dexpan would fare against a stump?
To expensive to buy a whole bucket but you might find someone willing to part with part of a bucket.
Might not push the wood far enough apart to separate the fibers. To much tensile strength I suspect
Old 03-27-2011, 08:01 AM   #12
Stay-at-home GC
No doubt! Don't know what relation your palm tree is to a Locust tree but if any you'll get the pleasure of digging it out numerous times over the next ten years. Darn thing keeps sprouting all over the yard.
Old 03-27-2011, 09:19 AM   #13
Civil Engineer
Rewards Points: 4,938
I removed a large white pine stump by drilling a series of closely spaced 1/2 inch diameter vertical holes into the stump using an electricians bit, about 18 inches long. I poured kerosene into each hole, let it sit for several days, then burned it. Worked fine. DO NOT USE GASOLINE, unless you are looking to kill yourself. Do not overuse the kerosene, you are looking to saturate the stump, not get kerosene into the ground.
Check with your local fire department first, you may not be allowed to burn in your area.
Daniel Holzman is online now   Reply With Quote
Old 03-27-2011, 09:40 AM   #14
kwikfishron's Avatar
Rewards Points: 996
You can rent a Stump Grinder.
kwikfishron is online now   Reply With Quote
Old 03-27-2011, 10:34 AM   #15
I have done:
  • Chemical decay accellerator - after a couple three years the stump was very soft, and then a bit of easy work with an axe made it go away several inches below ground level.
  • Dynamite - quickest way on the farm when clearing several stumps
  • Stump grinder - quickest way in a residential area
How to remove Built-in Electric Fireplace Almighty Building & Construction 1 11-12-2009 05:18 PM
Cannot remove haze from tile grout Woody36 Flooring 1 10-12-2009 08:54 PM
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 09:15 PM
Rotted Sill Plate and Joists jhawk4ever Building & Construction 2 08-30-2009 08:03 PM
Need to remove toilet temporarily pomelo Plumbing 4 08-22-2009 04:39 PM
