Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 10-04-2012, 11:40 PM   #1
Best way to fix nicked irrigation wire?
I was digging around the yard in a new house and managed to hit the sprinkler system pipe. It seems I also managed to nick the white wire, which I assume is the common wire.
What is the recommended method to fix? Since the wire is not actually cut, I'd love to use the most non-invasive means possible.
denkenz is offline   Reply With Quote
Old 10-05-2012, 07:22 AM   #2
To do it right your going to need a kit like this.
http://www.ebay.com/itm/ETCON-SK830-...item2c673c2ead
Any Lowes, HD, electrical supply house will have what you need.
Now that the insulation has been cut moisture can get in and corrode the wire.
Just make sure to kill the breaker on that circut before working on it.
Old 10-05-2012, 09:38 AM   #3
My local HD at least did not have anything for a wire size this small
Old 10-05-2012, 05:42 PM   #4
Surely they have this.
http://www.buyheatshrink.com/
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
sdsester (10-06-2012)
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
Dimmer switch with Hot & Neutral wire ? Knucklez Electrical 3 12-28-2010 05:24 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
