11-21-2010, 08:25 PM
#1
Landlord
Best way to attach rails to 4x4 posts when building a wooden fence???
Any suggestions?
11-21-2010, 08:54 PM
#2
Civil Engineer
Help us out, describe your fence and rail system in detail, maybe even a picture.
11-21-2010, 09:24 PM
#3
Master General ReEngineer
Ayuh,.. Lag bolts, 'n flat washers...
11-22-2010, 08:41 AM
#4
Don't know it all, yet!
Lag bolts or screws, depending on how heavy the fence is and how much you want to conceal the fastener. Lags are stronger but will show more.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
11-22-2010, 09:45 AM
#5
Landlord
Maybe this will help
11-22-2010, 11:36 AM
#6
joist hangers
Go ahead and apply for a variance, those guys at City Hall can use a good laugh. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
11-22-2010, 04:18 PM
#7
for a painted fence, I like to cut mortises in the posts and insert each end of the stringer. The tenons are cut at a 6 or 7 degree angle and the face of the stringer cut at the same angle so it is flush with the front of the posts. Lets the stringers shed water away from the pickets. Requires the stringers be installed with the long edge horizontal rather than vertical.
11-23-2010, 10:11 AM
#8
I like the Mike in Arkansas solution, but don't like having the long edge horizontal. I find that the stringers are more likely to sag, which bothers me.
Since it appears you want the face of the stringer flush with the face of the post, simply cut a slot in the face of the post equal in cross section to that of your stringers. Set the stringers in the slot. Glue and screws later and you are done. More elegant would be a lap joint.
Having said this, most such fences I have seen simply attach the stringer to the face of the post with nails (I would all polyeurethane glue). I am sure this is perfectly functional, but not very elegant. On the other hand, this avoids removing material from the post, avoiding any degradation in strength.
11-24-2010, 07:00 PM
#9
Maybe cocean could tell us if this a utility fence, decorative, etc. Several good ideas have been posted  but some are a lot of work for a dog pen.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
