Best Paver Leveling Sand? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-02-2012, 09:29 PM   #1
best paver leveling sand?
im ready to lay my pavers, but cant find any info on which product is best for leveling sand, everything i read on lowes and home depot reviews are bad.
bmilhansen is offline   Reply With Quote
Old 08-03-2012, 10:15 AM   #2
Rewards Points: 660
Not sure what you mean "what product"?
If you have your base aggregate down and compacted, all you need are two pipes and a board. I took a clas at one of the local paver supply places and the said lay down two metal (metal, not plastic which will flex) pipes whose widths are the approximate sand depth you need (1"?) paralles to each other. Pour the sand around them and screed level with a straight 8' 2x4. Pull the pipes out carefully and fill the holes they left.
Its easier than it sounds, I found out when doing my 400 sq ft patio last summer.
B
Beepster is offline   Reply With Quote
Old 08-03-2012, 10:42 AM   #3
I mean which brand of sand, they all have bad reviews
Old 08-03-2012, 12:53 PM   #4
Rewards Points: 660
Reviews? Sand is sand.
How many sq ft is the project you are doing? Are you talking the layer of sand on top of the aggregate that you are laying the pavers on, or are you talking about the sand that you are sweeping over the top to fill the spaces between the pavers?
B
Old 08-03-2012, 03:03 PM   #5
concretemasonry's Avatar
Rewards Points: 2,578
The setting bed that is over the compacted base should be uniformly 1" thick and ordinary concrete sand is readily available. The sand thickness to be uniform and uncompacted (just screeded). I drainage is needed, the base should be contoured to provide the needed slope, if any.
The sand to cast on the pavers after they are set with tight joints could be concrete sand since the gradation specification are quite loose. It can be used if it is on the fine side, but often masonry sand for mortar is used. Don't bother with the expensive polymeric sand unless it is a small job and convenient. - I have never seen polymeric sand used on a serious paver installation.
Too thick a setting bed can cause "floating" and low spots in the future.
Just vibrate with a plate vibrator to make the surface uniform and draw some of the setting bed up into the joints and force the cast surface sand down into the joints to create the strength and stability of the surface.
These are relatively standard construction steps/method for interlocking concrete pavers world-wide for decades.
If you are using larger units (over 12" in any dimension), they are not really pavers, but usually just "stepping stones" that have less strength and stability when installed.
Dick
concretemasonry is online now   Reply With Quote
Old 08-04-2012, 09:40 PM   #6
Rewards Points: 3,414
You want number 2 torpedo sand,the same thing they use for concrete.
Canarywood1 is offline   Reply With Quote
Old 08-04-2012, 10:48 PM   #7
B
roughly 320 sq feet, im inquiring about the sand on top on of the aggregate.
Dick
Damn i was told the bigger the paver the more stable =( im using 15 3/4" . Lowes website is wrong on dimensions but thi is what i am using http://www.lowes.com/pd_60096-215-10...3036362&rpp=48 . I guess i will use the quikrete all purpose sand
Old 08-05-2012, 07:49 AM   #8
bmilhansen
For a patio, the larger units (16x16) will be adequate because it is unlikely you will not have a car or truck driving on it.
The smaller pavers are thicker, more precise and have more area for contact at the joint that gives the real strength.
The pattern of the laying also can give more strength because of the different shapes and a generally rectangular (not square) allows allows different patterns like herringbone than have more stability.
Dick
Paver Joint Sand question: why is my sand so easily washed out? htabbas Concrete, Stone & Masonry 1 06-24-2012 08:04 AM
leveling sand question in DIY paver project htabbas Concrete, Stone & Masonry 1 05-08-2012 07:51 PM
finishing paver patio - what sand? H.O.P. Landscaping & Lawn Care 2 07-20-2011 03:00 PM
Paver Sand and Blue/Grey Colored Bricks Curious123 General DIY Discussions 4 08-13-2009 09:22 PM
Paver Patio w/ Polymeric Sand Kyle Landscaping & Lawn Care 3 04-27-2009 07:55 PM
