Best Ground Cover At Base Of Fence? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-11-2012, 10:30 AM   #1
Rewards Points: 310
best ground cover at base of fence?
Hey all,
I'm putting up a split-rail fence with the wire to keeps dogs in/out. This will cut across a boundary between my property and my neighbor's, which is presently one giant flowing combined little field of bermuda grass.
I want to make mowing easy for both myself and my neighbor, although anything I do will be 100% on my property. Ideally, I don't want to have to go over onto "his" side and mow a strip - I'd have the fence near the property line.
But if I put a 1-2 foot lane of pinestraw or something else under the fence - then there are two long seams that would need to be edged.
So ideally, on his side at least - I'd prefer if he could just simply ride his riding mower down the edge as usual -that's all. But I can't think of an edge type (for his side) that would be maintenance-free (no edging required). Any ideas?
denemante is online now   Reply With Quote
Old 06-11-2012, 11:21 AM   #2
PE Mechanical Engineer
Thunder Chicken's Avatar
Rewards Points: 844
You could put down a strip of quarry dust around the posts on either side. Keeps stuff from growing around the poles but mowers will go right over it without major risk of kicking a rock.
Thunder Chicken is offline   Reply With Quote
Old 06-11-2012, 01:15 PM   #3
MarginallyQualified
Rewards Points: 2,464
Similar issue here.
I'm >< that close to putting down a 2" bed of 67 gravel.
That and a twice annual dose of RoundUp should do it.
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 02:54 PM
Water well above ground tank cover. pattyinez General DIY Discussions 4 01-02-2012 01:03 PM
Sink base vs regular base cabinets... J187 Kitchen & Bath Remodeling 3 12-03-2010 07:40 AM
Above ground pool cover question joeg679 General DIY Discussions 8 08-03-2010 04:41 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
