Bearing For Drive/blade Spindle - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-28-2011, 01:46 PM   #1
bearing for drive/blade spindle
How do you take the pulleys off of the shaft to get to the bearings to change them or do you buy the spindle and the shaft and the pulleys seperately
mhern09 is offline   Reply With Quote
Old 06-28-2011, 02:51 PM   #2
Rewards Points: 52
Okay, this is a big stab in the dark, as I can only assume that you are talking about lawn mower deck spindles, since it is under landscaping. In general, the spindles, bearings, and sheaves or pulleys are individual items that you would purchase and replace individually, as needed. The sheaves or pulleys are typically going to be mated to the spindle with a woodruff or square key, and held in place with some manner of set screw, whether recessed allen type, or a simple cap screw located on a shoulder. With the screws removed, you should be able to separate the components, with various degrees of difficulty, depending on quality, wear, rust, abuse, etc. The bearings are typically pressed in place, such that they need to be pressed off. Sometimes a large bench vice or C clamp, along with some strategically placed sockets, pieces of steel, etc. can be enough to separate them, but other times a press is required. Many local machine shops or auto parts stores are so equipped, and can assist you for a nominal fee.
Finding Load Bearing Walls Dane Hitchins Building & Construction 15 05-14-2011 11:09 AM
Removing bearing wall and putting up a beam Sardinia Building & Construction 2 02-21-2011 07:11 AM
Load Bearing wall or not? Dennis6950 Remodeling 5 02-01-2011 09:34 PM
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 05:33 PM
Bearing wall, HELP me please jamiedolan Building & Construction 7 11-03-2008 12:33 PM
