Basement Flooding - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 12-30-2011, 02:56 PM   #1
Question
basement flooding
During rainy season water floods into my basent. It floors through the floors and corners of the whole. I want advise on how to stop it
mollenm is offline   Reply With Quote
Old 12-30-2011, 04:31 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Just tell it "NO" in a real forceful voice.
You aren't likely to stop it. Some more information would be real helpful tho.
Do you care to volunteer some information or do you need a list of questions?
XXX
Old 12-31-2011, 03:23 AM   #3
Thumbs down
You aren't likly to stop it. Some more information would be real helpful tho.
I ve hired a contractor to dig down where the water was oozing and he put concrete and waterproofing. The following week it rained and water found another spot in the basement floor to penetrated. Now I'm not sure if I close that one the water won't look for another sport
Old 12-31-2011, 08:14 AM   #4
Civil Engineer
Rewards Points: 4,560
This topic has been discussed at least a dozen times on this forum over the past two years. I suggest you search "French Drain", "perimeter drain", "wet basement" and similar to see what has been said. You will find threads on installation of exterior perimeter drains, interior perimeter drains, use of Drylok and similar paints, and sump pump installation. Design of an effective system requires careful analysis of the geometry of your house and the groundwater flow. This is going to require a site visit by a knowledgeable professional, but you can learn about alternatives from this forum.
Old 12-31-2011, 10:31 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Usually the only hope is to manage the situation favorably. Landscaping and proper water management on the exterior is the first place to look to make some adjustments.
XXX
Old 12-31-2011, 04:08 PM   #6
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 54
Your weeping tiles may be clogged, and/or the seal around the basement walls is broken. I have similar issues with my basement, next summer if I have the money I'll be digging it all up and putting blueskin or similar product, and new weeping tile. The materials are not expensive, the labor is though. I'm still debating between doing it myself or contracting it out. It's a pretty big job especially if you don't have a truck.
Either way, the only way to truely fix the issue is from outside. Sloping helps to some degree, but idealy a foundation should be able to hold water out even if it's just sitting there. That's the idea behind it. The weeping tiles then drain it out.
Old 01-01-2012, 08:07 AM   #7
Rewards Points: 1,440
Do you have a weeping tile system? (If yes then there will almos always be a sump pump.)
If you need to install or re-install a weeping tile system usually it is easier and less expensive to install it on the inside perimeter of the basement and that almost always works satisfactorily.
The first order of business is to correct the landscaping and grading so water does not lap up against the foundation.
If the water table is higher than your basement floor and you seal one portion of the basement, then the water will definitely seek another location to seep up into.
AllanJ is online now   Reply With Quote
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 11:50 AM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
Basement Flooding! matasw Plumbing 11 01-27-2010 10:59 AM
Help With Basement Flooding !!!! gottabee Building & Construction 45 01-19-2009 06:42 AM
