#1 |
Bamboo fence - strong enough?
Cursed with a short block wall I'm weighing up my options for making it more private. An option I have is to build a new inner bamboo fence, within my yard.
Two reasons I like this idea are the yard layout would accomodate it very well, and I already have most of the raw materials. I have 8ft tall 2" diameter bamboo poles, and loads of 6ft high reed privacy screening plus some other screening materials. The crucial question I have is about the bamboo poles. I suspect they are strong enough to support a 6ft fence, because bamboo has one hell of a reputation for strength. But how far into the ground do they have to be set? 2ft down would be perfect, leaving 6ft above ground to support the fence. I imagine using some kind of concrete to "plant" them in. So would 2ft below ground be enough? And would the bamboo weather well outdoors? Any advice would be great |
#2 |
Average Joe/ex-Navy IC3
How large in diameter are we talking for the poles?
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
#3 |
The poles are 2" diameter at base, and narrow to about 1.5" at top.
#4 |
Where are you located?
#5 |
I'm in Chandler Arizona
| Display Modes | |
| 6' wood privacy fence questions | snosurfa7 | Landscaping & Lawn Care | 13 | 06-01-2012 02:45 AM |
| Reuse Concrete Fence Post Pier & Fence Post Extraction | JasonCA | Landscaping & Lawn Care | 2 | 03-24-2012 09:58 PM |
| How to add a dividing fence to chain link fence and house with siding | catburke | Building & Construction | 0 | 09-20-2010 02:39 PM |
| Largest Crown Molding Cut on DeWalt 716 | Klawman | Carpentry | 8 | 11-14-2009 09:05 PM |
| How strong are fence posts? Suggestions? Thoughts? | johnluk | Building & Construction | 8 | 06-01-2009 08:37 PM |
