Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 02-26-2012, 12:01 PM   #1
Backyard on a slope -- drainage problem
Hi,
I am having an issue with water coming down the hill into my backyard (undermining the small terrace wall) and turning the lower portion of my backyard into a pond.
Last summer I did some digging and found a 4" corrigated pipe that while full of mud, seemed to be part of the problem. I cannot determine if it is draining an adjacent property (homes on hill above my house) or even draining a spring. Since I couldn't find it's source I went ahead and capped it off (affixed cap with silicone) to see if it made a difference. It seems to be helping, but significant moisture can still be seem in the terrace directly in front of the cap. When the house was purchased this was not a problem, only has become an issue within the last year.
I have attached a picture with illustrations showing where water is coming down the hill into my backyard, and where the capped pipe is located. If anyone has any experience with this type of problem, please feel free to provide your comments. Thanks in advance.
frumdogg is offline   Reply With Quote
Old 02-26-2012, 12:09 PM   #2
You could dig a French drain and install a sump pump and pump the water away to another area. Just a suggestion.
Writer’s information is for discussion purpose only and should be confirmed by an independent source.
Hardway is offline   Reply With Quote
The Following User Says Thank You to Hardway For This Useful Post:
frumdogg (02-26-2012)
Old 02-26-2012, 12:41 PM   #3
I was thinking about having it all collect into a sump and then piping into the lower part of my yard then connecting it to the drain that runs to the street. Alot of digging for a weekend warrior
Old 02-26-2012, 01:14 PM   #4
Concrete & Masonry
For a sump, I would highly recommend using a concrete catch basin rather than a cheap plastic sump. It's a little more work to get it in place, but will serve it's purpose FAR longer than anything else.............
jomama45 is online now   Reply With Quote
The Following 2 Users Say Thank You to jomama45 For This Useful Post:
frumdogg (02-26-2012), Hardway (02-26-2012)
Sub pump drainage problem bobtheblindguy Building & Construction 0 03-09-2011 07:35 PM
Garage siding too low (at grade), plus drainage problem pfisch Building & Construction 14 03-10-2010 11:41 PM
Backyard drainage rick32 Landscaping & Lawn Care 6 08-25-2009 11:34 PM
Sump pump drainage problem sk8z Plumbing 6 11-29-2008 11:09 PM
Drainage problem - Rain Barrel? Leah Frances Landscaping & Lawn Care 4 01-30-2008 07:20 PM
